Knocking in engine 03 cummins
The truck is on its way to the dealer to be checked out, it was still covered under the 7yr/100k engine warranty. Dealer syas he thinks it is an injector, but he is hesitant to commit to a diagnosis without first seeing the truck and having a peek.
Has anyone been hasseled by their dealer for having a boost and EGT gauge? Only other mod I have is a Magnaflow 4" exhaust.
Thanks for all they replies they were very informative and helpful, I will be sure to report back with the diagnosis from the Dealer.
Just heard from the dealership. Failed Injector was the cause of the knocking/smoke issue, the tech said the injector was stuck wide open, they are installing a new injector tommorow morning and will reassemble and run the engine to check for damage due to overfueling.
On a side note, should I be concerned they are only replacing 1 injector? Is there anything I can do to prevent another injector failure? I currently change fuel filters every 8k, any other things I can do to minimize the chance of failure? Pricing injectors has me a little gun shy should this happen outside of warranty.
Unfortunatly Dodge only chooses to replace the failed injector. Usually another will fail within a few months. I think that Dodge's policy is to replace all only if 3 or more are bad. Maybe you can convince your dealer that others are causing you problems where thay might get all replaced? Just a thought and might apply only if you are friendly with your local dealer......
Crap, thats what I was afraid of. I will call the dealer in the morning and speak with the service advisor, as she mentioned a different course of action under warranty if the truck was modified. I will have to talk with her and express my concerns. Really haven't been to the dealer for things other than trans filters, coolant flush, that sort of thing. I buy filters in Bulk through my father who is a Chrysler tech and up to this point the truck has been trouble free.
passnu2
Dec 19, 2004 09:09 PM
