Jacobs Exhaust Brake - pyro tap?
Old May 30, 2007 | 01:21 PM
HOV's Avatar
HOV
I'm having a Jacobs brake installed in my truck today. Saw in some literature that it has a pyro tap? Can anyone verify this for 2006 automatic models?
That would be sweet. I was dreading tapping my downpipe.
As for tapping pre-turbo, no thanks!
Old May 30, 2007 | 01:37 PM
CTDinMT's Avatar
According to the Cummins site, it is tapped for pyro. Any reason why you don't want to run pre-turbo?
Old May 30, 2007 | 02:28 PM
HOV's Avatar
HOV
Thanks for the response.
I'm just super paranoid about stuff getting in there, whether it's from the install itself or from something not from the factory breaking off and sailing downstream.
Old May 30, 2007 | 02:51 PM
Pooter's Avatar
Havent had a problem with 2 trucks, and 3 probes...
Didnt drop the turbo, just step up the bits gradually, vaccuumed it out before starting her up and havent had a single problem. I have two pre-turbo egt probes on my '05(one for the edge, one guage)
Old May 30, 2007 | 02:52 PM
carharttfarmer's Avatar
ya theres a plug in the jake elbow but it use high temp locktite so you will have to heat it super hot or you never get it out
Old May 30, 2007 | 06:56 PM
HOV's Avatar
HOV
Great advice, thanks
Old May 31, 2007 | 09:10 AM
ya i dint know that when i tryed to take mine out so the 1/2 impact did a real nice job of rounding it off so i would try to get it out before its on the truck
HOV's Avatar
HOV
Does anyone know if the fitting is 1/4" or 1/8"?
Old May 31, 2007 | 01:38 PM
HOV's Avatar
HOV
In case anyone is searching for this information, I emailed Jacobs and they replied saying the tap is 1/4 - 18 NPTF.
Astue observers will note that most pyros are sold with either a 1/8 or 1/4" NPT fitting, so it begs the question as to whether a NPT application will be okay in a NPTF fitting. Information on NPT vs. NPTF can be found here:
http://en.wikipedia.org/wiki/NPTF_Taper_Pipe_Thread
And I did find this other link that said it's okay to use a NPT application in a NPTF fitting:
http://www.cutting-tool-supply.com/T.../NPTVsNPTF.htm
But I think I'll start another thread to ask the gurus around here just to make sure.
Old May 31, 2007 | 01:50 PM
HOV's Avatar
HOV
Well, Jacobs emailed me back and said:
Dave,
I'd use a 1/4- 18 NPTF fitting, like God intended.
Why ask for trouble?
So I guess I'll be looking for a gauge that uses that fitting!
Old May 31, 2007 | 03:18 PM
edtyler's Avatar
Port plug is hard to remove
When I did mine, I was surprised to see that the end of the 'plug' was actually torn metal, implying that it was sealed in place after assembly. I was a little concerned about the integrity of the remaining female threads, but the probe bushing went in fine and sealed up well.
I did have the brake in place for about 5K miles before installing the pyro probe, so maybe operation melted the sealer.
Old May 31, 2007 | 04:30 PM
HOV's Avatar
HOV
What pyro fitting did you use? NPT or NPTF?
Old Jun 1, 2007 | 01:22 AM
edtyler's Avatar
Used fitting that came with Quad Commander
HOV,
I presume it was an NPTF, but don't really know. I used a little never seize and checked for leaks later by looking for carbon traces. None found.
Old Jun 2, 2007 | 10:33 PM
Danavilla's Avatar
I also didn't know about the hi test Loc-Tite. I fought it and finally wound up drilling it out and retapping with 1/4 NPT. After that, it worked just fine. I wanted post-turbo so I could install a BD Cooldown with just one pyro.
Real happy with the function.
Dan
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
Utundra
Jan 27, 2008 08:22 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
