Installed injectors, rough idle P0193
Old Mar 31, 2015 | 07:09 PM
FastTaco's Avatar
Just installed 100hp injectors in my 06 cummins. Finally got it to start back up and it idles really rough and i keep getting P0193 high rail pressure codes. Is this just the air working its way out and maybe it will clear up or do I have a bigger problem? Thanks
Old Apr 3, 2015 | 08:20 AM
high bid's Avatar
Check to make sure all the fuel connections are good and tight. Any air being sucked into the system will cause rough idle. Might want to also confirm elec connections.
Old Apr 4, 2015 | 09:40 AM
BigIron70's Avatar
Cummins Guru
diagnostic tests may help you, read pdf
File Type: pdf
89dieselkong
Dec 5, 2010 04:48 PM
TX Tech Wes
13
Feb 4, 2008 07:45 PM
StrokeThis2500
Mar 2, 2007 02:41 PM
Syndicate
Nov 23, 2006 07:50 AM
fanofthewolf
Feb 12, 2004 12:22 PM
