quad causin check light p0193
Old Mar 1, 2007 | 07:44 PM
StrokeThis2500's Avatar
just got quad standard adj model today plugged it all up checked all connections greased well. drove about 9 miles stoped to get a haircut came out started the truck and drove not even half mile truck acted like it was goona die out then check light came on with code p0193
(model was on stage 2) drove about 1/4 mile and it did it again ... when it does it the engine sounds pretty weird cant really explain it but sounds like its clattering more and crisper than usual... drove another 1/4 mile same thing... then got out on a main road and drove to the gas station checked connections and drove about 4 miles to where im at now with no problems except check light i got here and re greased all connections and still has check light on.... any suggestions
Old Mar 1, 2007 | 08:29 PM
Anybody have any ideas... is it ok to drive
Old Mar 1, 2007 | 08:35 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Call Quads tech line at 1-888-842-6572 Tomorrow and they will help you iron out what ever the issue is.
Old Mar 1, 2007 | 09:14 PM
Luvnacumns's Avatar
Happend to me quite a few times with my quad. It was a bad wiring harness.. Truck would run fine then fall on it's face. Call Jeremy @ quad and they will hook you up!!
Shane
Old Mar 1, 2007 | 10:50 PM
qzilla's Avatar
Just based on this explanation I am guessing there was something wrong with the connection. Basically if one of the connectors was not seated well it will easily cause problems. It looks as if it might have worked properly once you stopped and checked stuff. Now you said checking but, I am assuming you pushed and messed with the connectors to make sure everything was good.
If this is the case it is perfectly fine to drive it. If the problem is gone the light will go out on its own if you do not have a way to clear it manually. Usually a day or two of driving and it will go out depending on how much you are in and out of your truck.
Now to know if it is fine you are going to have to drive it. If this keeps happening make certain you have the plugs in correctly on the rail. SOmetimes you can get one of them backwards and it can cause all sorts of problems. If it drives fine and the issue itself disappears then all is good. the light is not going to go out immediately.
Quad
Old Mar 2, 2007 | 01:31 PM
Hey guys thanks for the help.... well last night i drove it to the house about 15 miles from where i was at and turned it off went out later to go to the store and the light was off...
Old Mar 2, 2007 | 02:41 PM
abc4yew's Avatar
A little bit of dielectric grease on each individual blade is ok...too much not so good. Lube the male part and the female part will get lubed from the male part, no need to lube the female part....of the connector. ks
TX Tech Wes
13
Feb 4, 2008 07:45 PM
mxg342
Sep 6, 2007 11:26 PM
NickBeek
Aug 30, 2007 06:45 AM
Syndicate
Nov 23, 2006 07:50 AM
fanofthewolf
Feb 12, 2004 12:22 PM
