Injectors
Old Aug 26, 2011 | 03:08 PM
Mclair's Avatar
Injectors
So the crankcase is getting fuel in it and the injectors have 189,000 on them but truck still runs perfect but starts a little funny. Should i have them tested or just get some new injectors from f1 for 2,100 I miss my 12 valve
Old Aug 26, 2011 | 03:18 PM
06RAM2500's Avatar
Time for new or remand Bosch injectors.
Old Aug 26, 2011 | 04:51 PM
Mclair's Avatar
Don't think it would be worth getting them tested there is good shop that will test them for 50 an injector and have a buddy that has 5 injectors he is not sure if there good or bad one was spraying he just bought new injectors between all of them I could get 6 good injectors but spend 550 on getting them all tested
Old Aug 26, 2011 | 04:56 PM
06RAM2500's Avatar
How many miles on those?
Old Aug 26, 2011 | 04:58 PM
Mclair's Avatar
not sure?
Old Aug 26, 2011 | 05:13 PM
06RAM2500's Avatar
It's a catch 22. You def got 1 that's bad, but with as many miles as you got on yours, I'd replace them all, then do as you mentioned. That is have your buddies tested out, then go from there.
Old Aug 26, 2011 | 10:47 PM
OOPS's Avatar
When my CC filled with fuel it was not the injector itself. It was a seal someplace that only showed up when they did a high pressure test on the engine. Not really sure what the test was but I know they blocked of the return line to do it.
Old Aug 27, 2011 | 09:07 AM
firemanram's Avatar
JL Machine 231-853-2626
They are a Bosch Certified facility, $25 to test them & $250 to rebuild. If 1 of them needs rebuilt then they knock off the $25! There are only 3 Certified Bosch test facilities in the US, from what I know & Mass Flow is another one but they can't rebuild them! JL is who does John's (F1).
Old Aug 28, 2011 | 12:03 PM
Mclair's Avatar
I changed the oil and took it for a drive and noticed when it starts funny and when I get on it it will puff black smoke once and all the while the engine sounds fine. Im thinking an injector is sticking is there anyway to test it in the truck
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
