injectors!?!
What are the odds of all 6 injectors failing at the same time? I just got my truck back from the dodge house and they say all 6 are bad including the lift pump! This will be the second set in 50000 miles
Fuel
Loves and Pilot since the first time it happened I only get fuel at truck stops where the turnover is a lot. When is enough enough is bosch or dodge goin to get the point?
Cummins Guru
Sounds like you are getting fuel with water in it. Tme to change your filter system to something that actually catches the water before it gets to the CP3 pump and injectors. Pull the high pressure injector tubes out and if corrosion is present you have gotten water into high pressure side of your fuel system. Pull the FCA and see if any corrosion is there if not CP3 pump might be alright. You can do a fuel vol tst to see if it pumping enough fuel. I would also be dumping that tank of fuel and changing in tank pump as well. Pull the fuel filter and clean it out really good or it will find its way back into your fuel system and injectors.
could maybe only one fail and the mechanic says all are bad and trying to make some money off of ya.
a dealership where i live when a mecahnic fixes the car or truck they try to look for things that are bad and if they find someting wrong they tell the customer and if customer says fix i the mechanic gets a commision for there upsale.
also if the mechanic was to break someting they dont tell the customer. they write down what they did to break whatever it was and lets say a month goes down the road and the customer comes in saying you broke this then the dealership tells the customer to prove how the mechanic broke it. usaully the customer looses. cause the dealership doesnt want to pay for it.
sorry for getting off subject thought i would throw out that little fact that goes on with this dealership.
darrenG
Jun 21, 2005 10:24 PM
