Injector Knock
Old Sep 10, 2004 | 03:59 PM
  #31
HighTen's Avatar
DIESELS MAKE KNOCKING NOISES, it's the nature of the beast...
I know what you're saying but this knock we're all talking about really sounds foriegn to the sound of a Cummins. It's not a "normal" knock and to me it just sounds wrong.
Old Sep 10, 2004 | 10:18 PM
  #32
Badunit's Avatar
While knocking noises in a diesel are common, a knock that seems to come from one or two cylinders and not the rest is not normal.
Old Sep 11, 2004 | 07:21 PM
  #33
SAC600's Avatar
Hello All,
I am new to this forum and diesels for that matter, but I do love my 2004.5 600 Q/C 4x4 shortie. However, I think that I may have the infamous injector knock. I am getting about 13mpg city/ 18mpg highway, so I have no complaints about mileage and power seems to be awesome as well. But... I do notice a slight knocking noise when I go from neutral to drive at idle and also at 1500 to 1600 rpm during acceleration. I am located in Sacramento and would like to know if anyone can recommend a good dealer to take my truck to for service. All input is appreciated. Thanks in advance!
Old Sep 13, 2004 | 09:11 PM
  #34
Mixer Man's Avatar
SAC600 .that sounds pretty normal and with those mileage numbers I think you are ok . I drive concrete trucks with Cummins and man you ought to hear those L-10 and M-11's ........Cummins are clattery engines but outlast them all !! Thank god these don't have that metallic ring of the big engines ...flame meeting the metal I was told causes the ring .
Old Sep 14, 2004 | 11:18 AM
  #35
HighTen's Avatar
Would anyone say it's safe to say that this "knocking" sound is definitely one or more bad injectors? Does anyone have a story about getting injectors replaced and the sound going away? I am trying to whether to take the truck to the dealer or not.
Old Sep 14, 2004 | 01:09 PM
  #36
SAC600's Avatar
Mixer Man,
Thanks for the reply. I think that it sounds "normal" also, but I am paranoid due to all of these posts about bad injectors. I appreciate all input, especially from experienced diesel owners/drivers like yourself.
Old Sep 14, 2004 | 08:30 PM
  #37
jwtuc's Avatar
I had all 6 injectors replaced at 2,000 miles for engine miss . The pinging sound was reduced by half , but its coming back again at 9,000 miles ( but no miss ) .
Old Sep 15, 2004 | 01:25 PM
  #38
HighTen's Avatar
So I guess it's possible there's no connection between "bad" injectors and the pinging sound.
Old Sep 18, 2004 | 12:01 AM
  #39
bauer500's Avatar
I put some Diesel Additive when I filled up and it made a difference in the knocking. Says it lubes and quiets the pump, seems to do just what it says.
Old Sep 18, 2004 | 11:00 AM
  #40
Jerry R's Avatar
Sorry I haven't responded earlier but have been offline since Hurricane Frances. I have run 5 tanks of fuel thru my truck since having #5 injector replaced and every tank I have consistantly inproved by 1 MPG. I know average 16.5 MPG, I also think I have one more injector that needs replacing but it only knock once in a while. The truck still sounds much better, you know like a Diesel should and not like its about to through a rod. I have also decided NOT to use ANY ADDITIVE.
Old Sep 18, 2004 | 11:36 AM
  #41
txhawg's Avatar
Ok, how would a new diesel owner know what is considered severe knocking? Even for a first gen owner moving up (?) to a 600, the sound is completely different. When I shift into drive at idle, I hear a disticnt, rather loud, sound that sounds like tink-tink-tink-tink. Is this what everyone is calling injector knock? My dealer says it sounds like every other diesel, but I don't hear it coming from 3rd gen 555's my friends own. How do I know if I have a real problem or not? My mpg seems a little low, but pretty much in line with what I am hearing.
Old Sep 18, 2004 | 01:18 PM
  #42
Jerry R's Avatar
Well, on mine the knock occured between 800 and 1100 RPM's and made a very distinctive knock like a rod knocking. Normal diesel noise is more like a lite knocking and lots of valve like clattering. At least to me it seems this way.
Old Sep 18, 2004 | 10:20 PM
  #43
HighTen's Avatar
Yes, Yes! That's just what mine does. With my truck, if you're driving slow, about 850 rpm in 3rd gear, the sound goes on and off. It's about 1 second making the sound then 1 second not and this cycle repeats...
Old Sep 20, 2004 | 06:08 PM
  #44
Ron Civita's Avatar
I got the loud knocking at 7,000 miles. Was most pronounced at idle and in gear. Decided to try Hammerdown #1500 diesel fuel conditioner. After 3 days, the knocking disappeared. I just passed 10,000 miles and still very quiet. Just like the day I drove it off the lot.
Old Sep 20, 2004 | 07:30 PM
  #45
sajigore's Avatar
Arrow
I also had a mild engine knock. I took it to the dealer and they changed out the timing gears and the lifter rack, seems to be alot better. I too have the 70 mph vibe and have to wait for a fix. HERES A TIP, if you have many problems push for a full bumper to bumper 100K warranty, they just might give in.
