injector install
injector install
hey guys, I just want to be perfectly clear on one of the instructions I have hear, I figure better to be safe than sorry. the directions call for me to install the rockers and crossovers in the "same order they were removed", now that can have multiple meanings. but I take it to mean install the rocker and crossover that came of of #1 valve, back on the #1 valve. they dont actually mean put them on in the same order I took them off right (start at 6 and work to 1)? I know I know, stupid question, but I really dont feel like destroying Don M's handy work.
thanks!
thanks!
I am gonna add to this. when connecting the high pressure fuel lines, I have to torque them to 22ftlbs, what kinda wrench do you use for that, I have a socket torque wrench, but obviously that wont work, it has to be some sort of open ended torque wrench or something....
They have crows feet sockets for that...i also think they have crows feet line wrench sockets. Should be able to get them at any sears.
No, you don't have to assemble it in any particular order, except the obvious of course. What they mean to say is: assemble all components in the same location as they were removed from. I always lay out the pushrods, crossheads, pedestals etc. and label them so they go back in exactly the same location and facing the same direction that they were.
Valve cover goes on last.
yeah, I put everything in seperate bags just to make sure it looks like putting everything back together should be the easier part.....but now that I have said that, its all going to go terribly wrong.
thanks for the input
I did a set last night, I removed air horn/fuel rail, then did ONE injector at a time, ...took out the injector, replaced the nozzel, replaced the o ring/copperwasher/ replaced the connector tube O-ring, then re-installed the injector....then moved on to the next one, once all injectors were done then I installed the fuel rail.
This way you cannot mix up parts.
I did not use a torque wrench on the fuel lines, I estimated the torque required.
I started at 8:30 and was done at midnight, and this was the first time I had done a set of 3rd gen nozzels
TJ0993
Nov 8, 2007 10:27 AM
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
oscaroc
Apr 2, 2005 12:14 PM
