View Poll Results: Have you had Injector(s) fail on your 3rd gen Ram?
Yes, Less than 25,000mi.
3.03%
Yes, 25,001-50,000mi.
10.61%
Yes, 50,001-75,000mi.
0
0%
Yes, 75,001-100,000mi.
1.52%
Yes, 100,001-125,000mi.
1.52%
Yes, 125,001-150,000mi.
1.52%
Yes, 150,001-175,000mi.
0
0%
Yes, 175,001-200,000mi.
0
0%
Yes, More than once
1.52%
No
55
83.33%
Multiple Choice Poll. Voters: 66. You may not vote on this poll
Injector failure
Old Jan 8, 2007 | 04:13 PM
cummins1279's Avatar
Question Injector failure
Just wondering what the failure rate is on the injectors in 3rd gen rams.
Old Jan 8, 2007 | 04:20 PM
DieselDo's Avatar
well I hope its a lot lower than the duramax. my 04 Dmax was in 4 times for injectors. probably the main reason I'm in a dodge now.
Old Jan 8, 2007 | 04:27 PM
honda_guy4's Avatar
Me too, sixohno ford was in twice for a total of 5 injectors, got rid of after second time, every winter a couple more were bad, that's why i drive dodge, hopefully this isn't a big issue
Old Jan 8, 2007 | 05:24 PM
drdigger11's Avatar
I had two injectors fail at the same time, then about two weeks later I had a third one go, replaced with OEM bodies and then decided to put 60HP tips on them while they were out at the dealer. Not cheap, could of bought a turbo if I would of done it myself. That was at 100000 miles, could of been the dyed fuel I use, but I do run additives, either Lucas or Redline. Also just wanted to say Hi and thx to everyone for all the great info.
Old Jan 8, 2007 | 06:08 PM
53 willys's Avatar
I voted No.....but my truck only has 7,000 miles on it.
Old Jan 8, 2007 | 06:59 PM
mitternocht's Avatar
Now another question is whose injectors are failing? Are the stock trucks failing or is a failure more likely in BOMBed trucks? Especially those trucks with pressure boxes? What about folks that run additives? Are there more failures with folks that run additives or not?
Here is a thread for example:
https://www.dieseltruckresource.com/...jector+failure
Old Jan 8, 2007 | 09:33 PM
dale29's Avatar
30,000 on mine so far so good
Old Jan 8, 2007 | 10:16 PM
FMB's Avatar
FMB
One stock injector at 97.5k miles. Failed closed, not open. Big difference.
Old Jan 9, 2007 | 02:25 AM
CUM4X4MINS's Avatar
A buddy of mine is on his third set in his DMax
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
werewolf
Sep 22, 2005 11:09 PM
2500TurboDodge
May 23, 2005 12:43 AM
underwoodtransp
14
Apr 28, 2005 05:02 PM
