Injector dirty?
Old Mar 17, 2014 | 10:46 AM
hotdog68's Avatar
Injector dirty?
So, I have a 2006 cream puff with 85,000 miles. Recently, I started getting a rough idle at startup with a little puff of white smoke. After about 1 mile or so it would clear up. So I put in an entire bottle of the grey Power Service and a full tank of diesel. I have used half of the tank, and now it still idles a little rough at startup (cold) but clears up smooth within one block. So it seems like the power service is working. There's is no blow-by and the oil level is perfect. I'm not getting any codes. Does this mean that the injectors are dirty or is one of the injectors going south?
Old Mar 18, 2014 | 06:40 AM
Pull Dog's Avatar
I had a similar problem with my 05 when I bought it 6 years ago. I used the recomended amount in a few fill ups and the problem went away for good. I continue to use the grey Power Service at every fillup. I would question your using an entire bottle at one time??!! I don't believe this is the correct way.
Old Mar 18, 2014 | 10:54 AM
shep1's Avatar
"Hows Meaner Cleaner" as directed should clean up your injectors.
Old Mar 18, 2014 | 04:26 PM
hotdog68's Avatar
Yes, I see your concern. When I read the directions on the bottle, which state that you double the amount in order to clean the injectors, I realized that I would be left with a small amount in the bottle (less that 8 oz). So, I decided just to poor the whole amount in. It was a full tank, so I'm hoping there's no negative results.
Last night I added a GDP MK2 filter kit, which supposedly filters up to 2 microns. I've been reading on here that the stock filtration of 7 microns is causing problems and that BOSCH recommends no less than 3 micron filtration. We'll see how it goes, I'll keep you guys posted.
Old Mar 18, 2014 | 06:58 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Using a full bottle is not going to hurt a thing
Old Mar 24, 2014 | 05:21 PM
hotdog68's Avatar
I've used up the whole tank of diesel with the Power Service Diesel Kleen in it. However, I still get the puff of white smoke at startup and it still runs rough for a block or so then clears up smooth. Could this be more than just a dirty injector?
ArcticWolf
Aug 16, 2005 12:11 AM
greenworks
Feb 22, 2004 12:00 PM
yrusoslow2
Apr 23, 2003 07:52 AM
tanderson2002us
Jan 2, 2003 05:55 PM
Dec 16, 2002 08:41 PM
