Injection pump
Old Aug 7, 2005 | 10:11 PM
bryanburns's Avatar
Question Injection pump
need to know injection pump prices,how much do they cost .maybe someone can give me a link to a site with some prices.i know one of you guys out there has a link to a good site.
Old Aug 7, 2005 | 10:19 PM
oestreich84's Avatar
If your looking for just a stock replacement I would check www.ebay.com. I think I saw one on there the other night for around $600.
Old Aug 7, 2005 | 11:25 PM
Dr. Evil's Avatar
For what year??? For your 04?? Isnt it under warranty....
Old Aug 7, 2005 | 11:33 PM
bryanburns's Avatar
i am looking for aftermarket,for the future after the warranty runs out. with my luck the pump will go out one day after the warranty runs out.
Old Aug 7, 2005 | 11:38 PM
Dr. Evil's Avatar
Uh...well that helps some....
Look into a FASS or Fuel Perporator:
http://www.dieselpp.com/
http://fleetmate.com.au/udpairdog.html
Either of these will keep your fuel system happy
As well, Im not a third gen guy but a FP guage probably wouldnt hurt either
Old Aug 8, 2005 | 02:05 AM
code7's Avatar
I recently had to replace my fuel injestor pump. These guys provided awesome service and replaced it with a rebuilt cummings part for half the price Dodge was charging. Southeast Power Systems. 4220 North Orange Blossum Trail, Orlando Florida 32804 (407) 293-7971
Old Aug 9, 2005 | 10:03 PM
bryanburns's Avatar
thanks for the links.i need some one to explain where the injector pump is located and do they go out as much as the lift pumps.i had mine fail 46,000mi do to gelled fuel at 20 bellow zero.use fuel tretment keep my filter clean no more problems.what can i do to keep the injector pump in good shape.
Old Aug 9, 2005 | 10:12 PM
RamWheelsBy4's Avatar
Power Service Diesel Kleen and Marvel Mystery Oil mix in every tank. I use 3parts PS to 1 part MMO and add 16oz to every fillup. Try it and you will tell the diffence in a tank or two. Buy both at wally-world, very inexpensive for the extra lubrication and injector cleaning. Mine runs much smoother and quieter with it.
Old Aug 9, 2005 | 10:52 PM
J BODY's Avatar
Yeah maybe I'm picky....but the CRD does not have an "injection pump". It's only a high pressure pump (actually two).
Old Aug 10, 2005 | 12:24 AM
yfz450guy's Avatar
cummins covers the pumps upto 100,000 miles or 5 yrs.
Old Aug 10, 2005 | 08:41 AM
nickleinonen's Avatar
one ended last week for $299...
Old Aug 10, 2005 | 08:52 PM
DR3500's Avatar
The "injection pump" (CP3) is located on the left side of the engine to the front. it is mounted to the gear housing. they don't fail very often, supposedly they can run by themselves w/o a lift pump. they only require a specific flow rate to live. I haven't heard of any failing yet.
Old Aug 10, 2005 | 09:20 PM
bigblock2stroke's Avatar
Right, its not an injection pump. Its just a fuel pump. Its job is to only pressurize the rail and the injectors to the actual metering.
In older diesels (pre 03 on CTD) the injection pump actually did the metering. The injectors would simply dump the fuel into the cylinder when the injection pump provided enough fuel pressure to "pop" open the injector.
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
