Ignition question
Old Apr 14, 2022 | 09:00 AM
Lcolleary's Avatar
Ignition question
So I have been having some problems where my 04 5.9L with 240k stalls out on me while driving. After trying just about everything under the sun, I noticed it will only happen if my key is in the ignition. If I start the truck, take it out while running, and drive off I’m fine. If I leave it in, I’ll die a mile down the road. Any ideas where I should start in terms of resolving this?
Old Apr 14, 2022 | 09:19 AM
FMB's Avatar
FMB
It sounds like your ignition switch is worn out. It is fairly easy to change out and you should be able to keep your original keys. On a side note, if you have a lot of keys on your key ring, it will put extra stress on the assembly.
Back to morning brew . . .
Old Apr 16, 2022 | 09:31 PM
gcssr's Avatar
Did you ever figure it out, it could be the oil pressure sensor, I believe that the oil pressure sensor is run through the E C M it senses low pressure it cuts the fuel back so you don’t burn the engine up I believe in your earlier post you mentioned the oil pressure would fluctuate, the sensor is behind the fuel filter housing , do a google search 👍
Lcolleary
0
Apr 14, 2022 09:06 AM
Falcon1
Oct 23, 2017 05:34 AM
whereswaldo250
Apr 3, 2013 08:29 AM
6.7L MegaCab
Oct 30, 2011 12:42 PM
jeepsuck
Jan 9, 2006 05:37 PM
