idleing for long times
Old Jul 14, 2008 | 05:56 PM
RBulldogger's Avatar
If you plan on ideling for over 10 minutes at a time I would have the high idle turned on. Idleing under 1100 rpms is not enough heat and pressure to "clean" the engine out. Idleing the engine above 1100 rpms wont hurt a thing other than your fuel tank and wallet
Agreed!...........
Old Jul 14, 2008 | 06:04 PM
billie's Avatar
Ran my 03 for 28 hrs one winter day/night to keep the trailer charged and warm when the generator quit at -24*. It idled up and down as it needed with no input from me. No ill effects and no significant smoke after.
I wouldn't do it normally but wouldn't hesitate to do again if needed.
Old Jul 14, 2008 | 06:16 PM
spooled05's Avatar
On my truck u turn the cruise on and press accel until desired rpm
Old Jul 14, 2008 | 06:57 PM
rich's Avatar
i've let mine idle 8 hours or more with no high idle feature and no problems have a buddy who idles more then i do and has no problems and his truck has over 200k on it 04 model
Old Jul 14, 2008 | 08:40 PM
NickBeek's Avatar
Originally Posted by cumminshakesit
i've heard of that too! i have tried also with no joy... the smarty has a high idle feature, but the guy who said he did it had no programmer...?? it was also a 2nd gen... any body else...
Once you have the option turned on, either by the dealer or by a smarty, you need a wire that goes into the ecm and connects to a ground (for manual transmission only). There should be a post on here if you search. The dealer if they even know about the option will try to sell you a "clutch switch kit" for $300, Cummins will sell you the exact same kit for $100. The only item from the kit needed is the ECM wire which is about $12 from Cummins. I found this out after I bought the kit from them. Any way it is a great feature and I use it in the summer to keep the cab cool, and in the winter to keep the engine happy and warm.
bigfoot
Jul 29, 2009 02:13 PM
Leon441
39
Mar 16, 2009 05:25 AM
green73
Oct 14, 2007 02:43 PM
wheels
45
Jan 10, 2003 02:53 PM
Grampaw
Nov 21, 2002 03:25 PM
