Idle in P or N?
Old Dec 7, 2006 | 10:07 AM
  #31
mule3010's Avatar
48 re does not circulate in park. If you don't belive this see if you can flush your trans in park. You can't, fluid does not move through cooler lines under pressure unless in N.(or a drive gear of course)
Joe
Old Dec 7, 2006 | 10:47 AM
  #32
paul4romtexas's Avatar
Okay, so if I am idling my truck, I should put it in N and then put the parking break on? Do this in cold temps and especially in warmer temps? The high idle DOES work in Park, but this is bad to use right? Lots of information on here, will someone summarize everything...?
Old Dec 7, 2006 | 11:53 AM
  #33
mule3010's Avatar
Basiclly idling in park for limited times is fine. Extended warm up periods or running for heat while sleeping/loading or whatever is better done in neutral. This is the first post I have seen where someone claimed real damage was done by idling in park. I am curious to know the circumstances underwhich that damage occured. Was it for 100's of hours, very hot,cold etc?
Joe
Old Dec 7, 2006 | 12:20 PM
  #34
HOV's Avatar
HOV
Originally Posted by DBLR
My high idle works in Neutral on my 2006 and yours should too.
Yep, you're right. I played with it again last night and it worked.
Old Dec 7, 2006 | 12:56 PM
  #35
no_6_oh_no's Avatar
Joe
IIRC, a TX truck, the batterie(s) died on the truck and instead of fixing it he let it idle on job site for about 10 hrs. The truck had 40k on it at the time and no issues until then. The originator of the pics was familiar with the truck and was very sure the long idle is what did it. The rest of the trans was good bit it messed up everything from the pump out.
Old Dec 7, 2006 | 02:58 PM
  #36
mic646's Avatar
All I can say is WOW!! A lot of good info.
With all of the warnings that are in my owners manual, one would think that dodge would put a warning about high idling.
Old Dec 7, 2006 | 10:07 PM
  #37
coparam4x4's Avatar
DC probably doesn't want to tell you to put it in neutral because if it slips in D or R and the truck takes off and kills someone...Guess who the lawyers will go after????
Ram1999
Feb 11, 2007 10:49 AM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
