Idle not returning
Old Jul 6, 2016 | 06:00 PM
bobsallyh's Avatar
Idle not returning
2003, manual trans. Sometimes the idle, about 700 RPM, doesn't return to that number. When letting off the accelerator it may hang up anywhere between 900 and 1100 RPM. Sometimes if I tap the brake it may come back or if I let the clutch out to go it will immediately come back. Doesn't matter if cruise is turned on or off. Same with the exhaust brake doesn't matter if on or off. TPS? Thanks for any ideas.
Old Jul 17, 2016 | 11:18 AM
bobsallyh's Avatar
Bump
Old Jul 17, 2016 | 04:29 PM
MikeyB's Avatar
Do the ignition key On/Off/On three times to post any error codes in the memory. Will display in the odometer readout.
Could be the APPS, or the FCA, or injectors dribbling.
hot_runner58
May 24, 2013 09:29 PM
pwrtripls1
Feb 9, 2012 08:46 PM
MudFlapper
Aug 27, 2005 10:47 PM
hotdram
Apr 19, 2005 05:53 PM
artstrong
Feb 14, 2005 06:53 PM
