identifying a differential
The easiest may be RPM at flat freeway speed , but not knowing what tires you have , its hard to use RPM , for that yr. the options were 3:73s & 4:10s .
I did not see a trans. in your sig. , auto/man.
Do you have stock tire size ? Or some other size ?
There should be a tag , held on by 2 bolts , hold the diff. cover on , get numbers off that .
If your going to keep the truck , you might want to get the vin. # and take to a dealer and ask for a build sheet , that will tell you anything you could want to know , unless its been modified .
notice your rpms at a certain speed while in direct (5th on a manual, drive with tc locked on an auto) and go here http://www.4lo.com/calc/gearratio.htm
streetsmoker
Feb 19, 2006 08:52 PM
piperca
Dec 5, 2005 09:55 PM
Gilberts2500Ram
Dec 4, 2005 10:09 PM
Turbo Deeezle
Dec 2, 2004 09:01 PM
