I can't get the search to work, what oil should I be using?
Old Jul 8, 2007 | 05:33 PM
Joe T's Avatar
Cummins says go 15K on oil changes if you're not using CG-4 oil... You have 3 options and even though I'd rather not go with CG-4 to increase my intervals I've read to not use the new oil for the emissions diesels since they don't lube right.
http://www.everytime.cummins.com/eve...aintenance.jsp
So which is it CI-4, CH-4 or CG-4 that is the new oil they have to use on the 07.5+ trucks?
Old Jul 8, 2007 | 07:05 PM
bluechrome's Avatar
mobil delvac 1 fully synthetic the best oil in my opinion. Amsoil is also really good
Old Jul 9, 2007 | 07:14 AM
MikeyB's Avatar
I would go with CI. Doubt you can find CG or CH on the shelves at most places.
Or you can use the new CJ oils.
MikeyB
Old Jul 9, 2007 | 08:49 AM
Joe T's Avatar
CI it is then. Why does cummins say reduce your intervals if using CG oils? I'm assuming that is the new oil and doesn't lube properly.
MikeyB, CJ isn't an option on that link I posted above.
Old Jul 9, 2007 | 09:38 AM
MikeyB's Avatar
CJ+4 is the new oil required on the new '07 emissions equipped engines.
MikeyB
DieselBoy20
Sep 23, 2008 06:51 PM
Jbolt001
Nov 10, 2002 09:23 AM
