I can't get the search to work, what oil should I be using?
Cummins says go 15K on oil changes if you're not using CG-4 oil... You have 3 options and even though I'd rather not go with CG-4 to increase my intervals I've read to not use the new oil for the emissions diesels since they don't lube right.
http://www.everytime.cummins.com/eve...aintenance.jsp So which is it CI-4, CH-4 or CG-4 that is the new oil they have to use on the 07.5+ trucks? |
mobil delvac 1 fully synthetic the best oil in my opinion. Amsoil is also really good
I would go with CI. Doubt you can find CG or CH on the shelves at most places.
Or you can use the new CJ oils. MikeyB |
CI it is then. Why does cummins say reduce your intervals if using CG oils? I'm assuming that is the new oil and doesn't lube properly.
MikeyB, CJ isn't an option on that link I posted above. |
CJ+4 is the new oil required on the new '07 emissions equipped engines.
MikeyB |
