Whine, roar noise
Old 06-07-2018, 03:15 PM
bobsallyh's Avatar
Whine, roar noise
2003 2wd quad, 6sp, dually. Strange noise to describe. At idle, ac off, at times a very slight "whine". After a stop, whine or roar will gradually get louder. Upon letting off the fuel pulling up to a stop, the whine will be same volume as the truck slows down, then before coming to a complete stop, the whine will quit. It sounds liking "spooling down". Same thing if I kick it out of gear at say, 50mph. Sometimes when making a very slight left or right, like on to an exit ramp the noise usually will go away until straightening out to continue on another road. I did notice the other day when towing our fiver, at exactly 66 mph the noise completely goes away. A little more fuel or less fuel and the noise is there. It doesn't really seem like a tire but at this point I'm totally confussed!
Old 06-10-2018, 04:23 PM
StealthDiesel's Avatar
Do your boost levels correspond with your noise?
Old 06-10-2018, 04:46 PM
Argo's Avatar
I had a similar noise in my 09 6.7, it ended up being a very slightly cracked exhaust manifold, it eventually cracked all the way and made the usual clacking exhaust leak sound but it started out as a high pitched whine....
Old 08-11-2018, 01:43 PM
bobsallyh's Avatar
The "roar" continued and last week the ABS and Brake light came on, showed right front wheel bearing. Replaced the hub and fixed it up. Lights out and "roar" gone.
StealthDiesel (08-21-2018)
CJSamples
10-30-2006 10:27 AM
bigbrowngoat
01-30-2005 03:45 PM
KenR
32
08-20-2004 11:23 AM
thatguy
08-04-2003 09:05 PM
KenR
36
05-18-2003 08:06 AM
Quick Reply: Whine, roar noise
