Hub removal
Old May 19, 2009 | 11:44 AM
lost one's Avatar
OK did a little searching and it appears the u-joints use the c-clips that are on the inside of the yoke rather than the ones on the end of the cups. Thanks for all the help you guys have been great and I appreciate it.
Old May 19, 2009 | 08:41 PM
5.9x2's Avatar
That is correct on the U-Joint clip, if you have done U-Joints before you will not have any problems. I am glad you got the bearings off without Damage they sure can be a pain. Now that you have put anti seize on them it will be a piece of cake. On my 94 I got were I could change a bearing in less than an hour.
As mentioned above if the bearing is stuck like these mentioned you will NOT get them off with a puller it will pull the bearing apart.
Old May 19, 2009 | 09:21 PM
lost one's Avatar
I have done U-Joints but it has always been the ones with the clips on the end of the cups, the ones with the plastic I took to Napa and had them do because I did not have a torch at the time.
It took two 2 ton jacks on the bolt heads, sockets trapped on the other bolt heads and I had to use a 5lbs. sledge on the piece that holds the bearing (cant remember the name of it) where the ball joints are, there is no doubt in my mind that using a sliding hammer would have pulled those bearings apart with as much as it took to get them off.
Old May 20, 2009 | 12:45 PM
2006Mega's Avatar
Originally Posted by steve05ram360
I just did carli uppers & moog lowers, new axle ujoints... getting the hubs off was easy for me, I used an 18mm deep socket with a super shorty 1/2 drive extention (2" IIRC) and did the power steering assist trick, worked awesome, both hubs came off w/o a hitch. just had to nudge both sides a little at a time, once it was broken loose, it came out easy.
if your truck has lived all its life i so cal then that would explain why it was so easy. here in the land of sand and salt everything corrodes together it seems.
Rafter B
Jan 11, 2009 08:40 PM
DiEseLjunKy
32
Dec 27, 2007 07:37 AM
Crimedog
Feb 27, 2007 10:39 PM
Berak
May 13, 2006 07:12 AM
Andy505
Sep 21, 2005 09:34 PM
