Hub Bearings
Old Dec 2, 2008 | 12:28 PM
Shepherd57's Avatar
Hub Bearings
Has anybody got any front hub bearings laying around from doing the Dynatrac swap that they would like to get rid of.
Old Dec 2, 2008 | 12:43 PM
bradler's Avatar
Does your 03 have the AAM 9.25 front axle, with the sealed unit bearings?
Have some but not much left by the time i got them off. Wasn't real careful as i didn't plan on re-using them and they were a royal PITA, nice and siezed up. Maybe someone else with a little more patience managed to remove a pair without destroying them...
If you find new ones put anti-sieze on during install, then when its time for balljoints they will come right off
Old Dec 2, 2008 | 03:01 PM
Shepherd57's Avatar
Hub Bearings
Thanks for the reply I had mine off to replace the u-joints about 2 years ago. When I put them back together I used lots of anti-seize so they should come apart fairly easy
Old Dec 2, 2008 | 04:18 PM
kprc51's Avatar
I have a set with about 15,000 Kms on them. Bought them from a member here trying to solve a front end vibration. Ended up to be an out of balance front drive shaft.
JR
Old Dec 2, 2008 | 11:06 PM
Shepherd57's Avatar
Hub Bearings
I have sent you a PM
Mutt68
Sep 25, 2012 12:51 PM
Rafter B
Jan 11, 2009 08:40 PM
iifid
Apr 19, 2006 12:08 PM
Shepherd57
Jan 15, 2006 12:42 PM
