Hub Bearings
Has anybody got any front hub bearings laying around from doing the Dynatrac swap that they would like to get rid of.
Does your 03 have the AAM 9.25 front axle, with the sealed unit bearings?
Have some but not much left by the time i got them off. Wasn't real careful as i didn't plan on re-using them and they were a royal PITA, nice and siezed up. Maybe someone else with a little more patience managed to remove a pair without destroying them... If you find new ones put anti-sieze on during install, then when its time for balljoints they will come right off[laugh] |
Hub Bearings
Thanks for the reply I had mine off to replace the u-joints about 2 years ago. When I put them back together I used lots of anti-seize so they should come apart fairly easy
I have a set with about 15,000 Kms on them. Bought them from a member here trying to solve a front end vibration. Ended up to be an out of balance front drive shaft.
JR |
Hub Bearings
I have sent you a PM
