How long did both battires last in your truck?
Old Aug 19, 2007 | 04:30 PM
RHC's Avatar
RHC
Still runing factory battires. No problems after 4.5 years. Thinking about changing them out after 5 years and replacing them with the red top optima battires.
Old Aug 19, 2007 | 04:46 PM
MikeyB's Avatar
I'm also at 4.5 years of ownership with the original batteries. The truck born on date is Oct '02.
MikeyB
Old Aug 19, 2007 | 05:30 PM
GEN_X's Avatar
September 11th my truck will be 3. with 245,000m still going strong.
Old Aug 19, 2007 | 05:54 PM
J BODY's Avatar
I'm on my third set of batteries. Originals started requiring cleaning weekly so I replaced with with warranty replacements (mopar/exide). They leaked worse the following summer so I pulled them to use elsewhere (racecar) and went with the spiral wound batterys Mopar offered at the time. They have been in since 04 and all I have to do is blow the dust off of them. No mess what so ever.
Old Aug 19, 2007 | 07:11 PM
qwest's Avatar
5 1/2 years, started cranking slow, un hooked 1 battery ( guessed right 1st try)
Cranked faster, bad battery pulling down good battery.
so 2 new batteries, 125$ total, with a terminal cleaner..
Old Aug 19, 2007 | 07:42 PM
CTDinMT's Avatar
4 years on the factory batteries. Still good to go.
Old Aug 19, 2007 | 11:15 PM
PourinDiesel's Avatar
If you were in a cold climate I would not recommend optimas but since you are in Alabama go for it.
Old Aug 20, 2007 | 01:43 AM
TexasCTD's Avatar
Do you mind explaining why you think that?
I am still running my stockers at a little over 3 years of service. But I had considered switching to Optimas when I felt it was time to replace them. I am in Texas so it is very warm.....but why wouldn't the Optimas work well up north too?
Old Aug 20, 2007 | 04:11 AM
In cold climates a more standard type heavy duty battery will usually have more cranking amps than the optimas.
Old Aug 20, 2007 | 06:46 AM
bulabula's Avatar
Thanks, I didn't know that about Optima's. My batt's are probabliy 5 years old right now and I've been thinking of changing them out before winter.
Old Aug 20, 2007 | 07:14 AM
bulabula's Avatar
Thanks, I didn't know that about Optima's. My batt's are probably 5 years old right now and I've been thinking of changing them out before winter.
Old Aug 20, 2007 | 07:44 AM
danc46's Avatar
On my 2000, the original batteries were still in the truck when I sold it in January of this year with 173K miles on it.
I'd clean the terminals off every once in a while but they never required anything else.
Old Aug 20, 2007 | 07:46 AM
levigarrett76's Avatar
the red tops have 800 CCA....whats wrong with that? they can last up to 10 years if you dont ever pull them dead....
I had a red top in my wheeling rig with a big block for 2.75 years, i abused teh crap out of it, the fan took a chunk out of it, i ran it dead with a winch many times and even pulled it down below 4 volts by leaving the ignition on a few times....plus the truck had a small current drain at the time. It was warrantied and i put it towards a yellow top and haventlooked back.
I had a 97 powerstroke that the oem battereis lasted 8 years...i think its a matter of how they are taken care of
Old Aug 20, 2007 | 10:54 AM
B-MAN's Avatar
??? Never had any problems with Optima's in the cold, I've run both reds and yellows @ -30* and colder...Maybe they sell us special Optima's in the north
Old Aug 20, 2007 | 11:18 AM
Rob Mitch's Avatar
My 2001 had a build date of May 2000, and I traded it in April 2007 with the original battiries in it. It would still crank great but the little green windows on the batteries wern't very bright any more.
