How to identify a 2004.5
Old Jun 26, 2008 | 11:30 PM
boony's Avatar
I am buying a 3500 diesel listed as a 2004. Is there a way to identify if it has the 600 series engine via the serial #?
Old Jun 26, 2008 | 11:59 PM
DieselBoy20's Avatar
Look on the drivers side of the valve cover, there will be a sticker telling you if its a 305 or a 325. I'm guessing thats what your asking right?
Old Jun 27, 2008 | 12:09 AM
Det 1's Avatar
Easiest way is to check the build date listed on the info label located on the inside of the driver's door. A build date after 01/01/04 is an '04.5. Another way is to check the label on the driver's side of the motor valve cover. An 04.5 model will have 325 hp; an 04 model has 305 hp.
Old Jun 27, 2008 | 12:25 AM
boony's Avatar
Thanks,
build date is 11/03 so I guess it missed the 600 by a month.
Old Jun 27, 2008 | 06:43 AM
D45's Avatar
D45
But, you also lucked out and there should not a catalytic converter under there either!
305/555 POWER!!!
gsdog1
Aug 3, 2004 10:01 PM
drno
Jun 18, 2004 06:57 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
