How to disable reverse honk
Old Oct 19, 2006 | 06:28 AM
reecegr's Avatar
still works on my 05 2yrs now.
Old Oct 19, 2006 | 04:31 PM
Jfaulkner's Avatar
Muted User
Originally Posted by Hannibal
Don't blame the lawyers or DC. Blame the creep who left his truck in reverse and got out of it and swore up and down he had it in park and it "jumped out of park" and sued everyone in sight. He should be beat about his head and body with a shift lever.
Do you people actually think that there were just a "few" trucks that this has happened to? You don't really think that they would issue a recall if this has only happened to a couple of people. the problem is with the dash indicator and the linkage to the VB. The dash says it's in park but the parking pin isn't fully engaged. It's really easy to do and we tried it with a 04.5 in a driveway, the dash said park but the truck moved backwards. The problem is Chrysler is too cheap to fix the problem so they just use the horn as a Band-Aid!
But then again I suppose actually learning how to back up without opening the door is totally out of the question! And since I know your going to ask I have a 6sp, I can shift on my own I don't need a computer to do it for me!
Old Oct 19, 2006 | 05:06 PM
Rollin Smoke's Avatar
Originally Posted by reecegr
All you guys need to do is unplug the 2 wire plug next to the seatbelt(drivers side 4 inches lower than where it buckles) then put a very small wire across the 2 leave it in there and plug it back in,This will disable the reverse horn honk, the seatbelt light and seatbelt ding.
Why not just leave in unplugged?? Or does that circuit have some other function?
Thanks
Old Oct 19, 2006 | 06:52 PM
tacook's Avatar
Seatbelt fix does not work on all vehicles (only 1 of the 4 4.5-05's at work) . Its not an unjustified problem, my shifter shows erratic errors in what gear Im in all the time.
Old Oct 19, 2006 | 08:15 PM
nickleinonen's Avatar
Thanks
plugging it back in holds the wire jumper in place i suppose.. you could get a scotch lock [evil little things eh?] and modify it a bit so 2 wires can cleanly pass through it, then crimp it into the wire pair.. not as pretty a solition, but would work...
i looked at the prints for the door switch, and all you really need to do is cut the door latch switch wire [built into the door latch, not a separate switch in the door jamb].. if you wanted to get fancy, you could run a separate wire to it and cross the wire from it to the rear door or pass door.. so opening the drivers door won't set off the alarm, but opening the pass side or rear door would set it off [and that way your open door will still light the interior light]
crossing the drivers front and rear doors would probably be easiest if you choose that route [just keep the kids from opening the rear doors when backing up]
Old Feb 12, 2007 | 03:38 PM
tdineverdie's Avatar
tried on my 06 and it did not work..
Old Feb 12, 2007 | 03:45 PM
belgianmagic's Avatar
OK... I have my middle seatbelt buckeled into the driversid at all times ...and it still HONKS ...
what does the 'OUT OF PARK' 'DOOR AJAR' AND 'SEATBELT' HAVE TO DO WITH EACH OTHER ???
DIDN'T SEEM TO FIX MINE
kyachovitz
36
Nov 9, 2013 12:55 PM
fredbert
379
Aug 17, 2011 11:52 PM
budbon
Dec 4, 2007 01:14 AM
dirt
15
May 2, 2007 02:11 AM
Gas-Man
18
Mar 17, 2006 11:06 AM
