Hmmm, that's wierd
Old Oct 6, 2009 | 09:36 PM
dott's Avatar
Yes, electric gauge.
I checked the connections and for a good ground. Looks good.
The pressure has gradually dropped over time and is now running about 18 unloaded.
I don't know what kind of pump is in the tank since it was that way when I bought it. Are there a lot of choices for in-tank replacement?
Still weird.
Old Oct 8, 2009 | 02:47 PM
bradler's Avatar
Just had a new lift pump put in the tank. I run an Isspro gauge with an isolator going into the cab and the same banjo tap at the CP3. I always used to see 8psi idle, 5psi cruising, and 1-2 psi wot with the old pump. New pump shows 13-14psi as idle now and 8-9 psi cruising without much more of a drop under heavy throttle. Maybe the new in tank pumps are stronger?? Do the 6.7L's use the same one?
Old Oct 8, 2009 | 07:37 PM
dott's Avatar
I don't know much about the pumps.
Mine has gradually gone back to the way it was when I first installed the gauge. Still Wierd.
Old Oct 14, 2009 | 05:45 PM
dott's Avatar
Update:
After a week at the initial pressures of 12-14, the reading has gone back up to 24-26 psi. I only drive the truck 1-2 times per week. Just highway driving then occasionally pull my 10K lb gooseneck.
Old Mar 18, 2011 | 07:05 PM
dott's Avatar
I know this is an old thread, but I just finished solving the problem.
The gauge has been reading 40psi (max) for the last year and a half. I just never got motivated to fix it since I typically only use the truck for towing and forget about it.
It wasn't an electrical problem. I found the following troubleshooting guide on Isspro's website.
http://www.isspro.com/TROUBLESHOOTIN...leshooting.pdf
Went through it step by step to find out that the sender is putting out a signal for 40 psi. Called Genos, they referred me to Isspro. Told tech support the story. Bottom line is they sent me a replacement sender under warranty. I have had the system for about 2 years, which I told them, and it never has worked correctly.
Ultimately good service, but a little slow in responding to phone messages.
Dodgezilla
Feb 22, 2005 07:03 PM
westcoaster
Dec 5, 2004 11:56 AM
ramlovingvet
Mar 18, 2004 07:34 AM
goelvis
Jan 5, 2004 08:05 AM
PADZZ
Feb 22, 2003 02:42 PM
