High Trans Temps
Old Apr 28, 2010 | 09:25 AM
CoastalDav's Avatar
Thanks for the reply.
Dave
Old Jun 1, 2010 | 04:46 PM
hoot's Avatar
230 is the upper limit. 240 you should do something to reduce temps.
The big BUT is where you read your temp from. The hottest readings are with a sensor in the line coming out of the TC. That's where I have mine. I have seen 240 but typically around town no lockup I see 220ish.
thebearof,
Do you have an inline temp sensor?
Old Jun 1, 2010 | 04:53 PM
hoot's Avatar
Originally Posted by no_6_oh_no
The trans temp sensor is part of the gov pressure sensor.
ATF+4 operating range is 140-240 degrees. Its at the top but not out of the range nor abnormal for an OE unit.
Here is the valve body. The sensor is on the left pulled out. The right side is the trans connector to the outside world.
WYLE-1
13
Aug 7, 2011 09:19 AM
kevins600
Nov 12, 2010 04:00 PM
masonic-dodge
Jun 14, 2005 06:14 PM
twhite
23
Jun 12, 2004 05:29 PM
whiteknight
Jan 8, 2003 10:51 PM
