help-tranny problems on the road
Old Dec 16, 2005 | 06:26 PM
candndelivery's Avatar
my husband is on the road 200 miles away from home. there is a loud knocking noise when he is in 6th gear. it runs fine in all other gears except 6th gear. he is currently running in 5th gear. Is there any suggestions or ideas of what could be wrong or anything he can do while on the road?
Old Dec 16, 2005 | 06:35 PM
Bad Ramer Jamer's Avatar
Where is he at. First thing I would do is check for code's. Is the check engine lite on. If not, cycle the key on and off 3 time's to see if there is a code.
Old Dec 16, 2005 | 06:38 PM
Mine was what sounded like spark knocking real bad. Sounded like a broke rod. Tell him I said to check that wire to see if it's shorted out. Me and him talked about it.
Old Dec 16, 2005 | 06:40 PM
there are no codes no MIL. It started with a light knock and now it is a hard knocking, still just in 6th gear. He is in Virginia.
Old Dec 16, 2005 | 06:42 PM
Ask him if he checked the wire by the a/c compressor pressure line for a short.
Old Dec 16, 2005 | 06:44 PM
make sure to check the oil for any metal shaving's. Is it running hot.
Old Dec 16, 2005 | 06:45 PM
it's not a miss, its just a hard knock coming from the transmission.
Old Dec 16, 2005 | 06:47 PM
Does it do it while standing still. If not, might be a u-joint. I'm just throwing out wild guess's here. I'm sure more guy's will be chiming in soon.
Old Dec 16, 2005 | 06:50 PM
He might have broke a gear or a sycronizer. Does it do it in reverse.
Old Dec 16, 2005 | 07:27 PM
RCW's Avatar
RCW
As long as there is no noise in any other gears, just do not use 6th until the transmission can be torn down. It is a good idea to reach under and feel the transmission and make sure it is not too hot to lay his hand on. If the transmission is hot, then he may have a low oil problem, and that will need to be addressed before he goes much farther in any gear. He more than likely has a chipped tooth or broken bearing in the 6 gear race, and the knock occurs every time it rolls around. The latter is by no means an unusual problem for trucks that pull heavy trailers.
Old Dec 16, 2005 | 09:12 PM
manganos's Avatar
let me know
Well if he ends up getting stuck and he is in the central va area you can tell him to call me and I'll come pick him up. If need be I'll trailer his rig back here. I'm located in Dinwiddie, Va. zip 23833 located close to interstate 85 and not too far from 95. 804-6914349. Hope everything turns out ok. Chris
Old Dec 16, 2005 | 09:20 PM
Well I made it back, I would say it is a chipped tooth or bearing it is very rythmic and is on in 6th, I didnt notice reverse, but I sincerely appreciate all the help, Ill have it in the shop on monday I guess, I know one thing it makes for a long trip not going over 60 and rpm at about 2600.
Old Dec 16, 2005 | 10:22 PM
Glad to see you made it home ok. I sure didn't think a 6 speed would break down. I guess even a poor old Dodge can give it up when you work em as hard as we do hauling those car's.
Old Dec 16, 2005 | 10:38 PM
I love my truck, but in the past 6 weeks my truck has been in the shop for about half that time, and that means $$$$$ down the drain, that sucks
Old Dec 19, 2005 | 03:10 PM
UPDATE: Took to the shop today, they're gonna try to tear it down this week and find the prob., when I got to the dealer it became very hard to shift into any gear and won't go into 6th at all anymore. Ill post the results hopefully this week.
