HELP pitman arm confusion
Old Nov 21, 2017 | 08:48 AM
jawsman@sbcglob's Avatar
I have 06 4x4 with level kit upgraded steering linkage was told on there needed new pitman do to different angle of the dangle ordered 09 pitman did not fit do to different box shaft size diameter installed linkage anyway and had no clearance prob. with orig. pitman. question what part # or year pitman do i need that has that different angle that will fit 06?
Old Nov 22, 2017 | 06:49 AM
Stamey's Avatar
I am not sure that you need one. If you don't have a big lift on it then there shouldn't be enough of a difference in the angle to justify replacing the pitman arm.
Chris
Old Nov 22, 2017 | 08:22 AM
will have to return or exchange part, wanted to know part # of correct pitman
could not get my puller on it looks looks a bugger to change
exsanguinate
Dec 14, 2009 04:13 PM
walkram42
Oct 21, 2007 10:08 AM
BigDan
Jul 8, 2006 11:04 PM
R Walter
Mar 21, 2005 09:40 AM
royalnine
Jul 18, 2004 08:56 PM
