HELP! Oil filter change
Old Mar 9, 2007 | 11:41 AM
ROOFGOOF's Avatar
I have never cussed so much! I bought the webbing/ratchet filter remover and I cannot get this stupid oil filter off! After trying for approx. 2 hours, the ratchet remover just broke!
I followed these instructions --- with NO LUCK! This thing is stuck on and its really edited by admin me off. HELP? SUGGESTIONS?
http://dodgeram.org/tech/dsl/filter/oil_filter.htm
Old Mar 9, 2007 | 11:51 AM
htgreen3's Avatar
if its the factory filter, I wish you luck. I finially drove a screwdriver through mine and got it loose that way. But, be ready for a mess. Before I drove the screwdriver through, I punched a hole in the bottom and drained it.
Old Mar 9, 2007 | 11:52 AM
ROOFGOOF's Avatar
Yeah its the factory filter... this is CRAZY! Just to review...if I was looking down at it, turn it Clockwise. If I was underneith the rig, Counter clockwise? Correct ?
Old Mar 9, 2007 | 11:56 AM
Spooler's Avatar
That is correct. Lefty loosey, Righty tighty as they say. I use a filter hat that fits on the bottom of the oil filter. 1 long extension and a 3/8 ratchet is all you need.
Old Mar 9, 2007 | 11:59 AM
ROOFGOOF's Avatar
My buddy is on his way with another strap. If we break that one, I will have to get one of the filter hats you mentioned about.
Thanks
Old Mar 9, 2007 | 12:22 PM
htgreen3's Avatar
Old Mar 9, 2007 | 12:29 PM
surfram's Avatar
The metal cap wrenches or "filter hats" work great. Using a long 3/8 extension, I get the filter loose and then put a large freezer ziplock bag up over the filter. When I take the filter off, it can drop into the bag and the oil spills out in the bag. I got the cap wrench from advance auto.
Old Mar 9, 2007 | 12:53 PM
ROOFGOOF's Avatar
Just tried the cap for about 15 minutes and no go... I am actually striping the inside of the filter hat. This is BS !!!!!!
Old Mar 9, 2007 | 12:55 PM
Spooler's Avatar
Somebody muscled up on that thing geesh!!!!!!!!!! You'll get it just be patient.
Old Mar 9, 2007 | 12:58 PM
HayHauler1's Avatar
I purchased a "chain wrench" at Autozone for a water pump job last year. I bet that thing would get it off.... Might deform it, but it would come off. Might make a mess too..
Hay
Old Mar 9, 2007 | 01:15 PM
Arkapigdiesel's Avatar
You tried a strap wrench? I can't believe that joker is on that tight.
Old Mar 9, 2007 | 01:19 PM
LongRanger's Avatar
Craftsman makes a filter that goes on the end of the filter like a "hat" type but has three engagement points. That seems to work the best. The filters are really put on tight at the factory.
Old Mar 9, 2007 | 02:40 PM
DBLR's Avatar
All the engines are clear coated at the factory (Cummins Plant) before they get shipped to Dodge so this clear coat covers every thing and causes the factory filter to be very hard to get off. I have used Channel Locks on filters in the past but being I had heard how hard the factory filter is to get off, I took it in to have someone else bust up their hands getting it off. I have also used a screwdriver punched though the filter to get some filters off but have from time to time ripped them in two so be careful if you try this.
Old Mar 9, 2007 | 03:16 PM
truckjunkie's Avatar
Yeah - my first one was a real pain too... I have the cap wrench, and it did do the job - finally. I think - if memory serves me correctly - I finally had to put a breaker bar on the end of my 3/8 multiple extension to cap wrench contraption before it'd come off.
Old Mar 9, 2007 | 03:31 PM
Turbobob's Avatar
My filter "hat wrench" uses a 1/2 inch ratchet...My first one was a little tough, but she gave in to the bigger ratchet!
