Help New 06 cummins wont start
Old May 25, 2006 | 04:47 PM
wardy70's Avatar
My buddy just called and said he shut his truck off to fuel up and it will not start. He said it seems to have all power but the starter will not click or engage. It is a 06 3500 dually with a cummins and a 6-speed any ideas?
Old May 26, 2006 | 02:14 AM
SSminnow's Avatar
Hard to say, but maybe the clutch safety switch. In other words, if the switch is bad, the starter thinks you have not depressed the clutch, and won't engage starter
Also, of course, check for loose connections...battery cables. Long shot, but little stuff like that can AND will happen.
Old May 26, 2006 | 10:07 AM
shortbus's Avatar
Does the switch still engage if its in neutral?
I dont have a dodge stick, but in other vehicles (a nissan comes to mind) when that relay went bad, it would still start if the stick was in neutral.
Old May 26, 2006 | 02:46 PM
4x4not's Avatar
Yup, even in neutral. You MUST depress the clutch fully to start these trucks.
Unless of course you bypass it, which I will be doing when I rig up the remote start in mine.
Old May 26, 2006 | 03:53 PM
ramtd02's Avatar
tell him to turn the key on and off 3 times too pull any codes....maybe the key has crapped out (skim key)
Old May 26, 2006 | 05:07 PM
Spooler's Avatar
Nissans you had to depress the clutch period. One thing that would go bad on them was the inhibitor relay. No contact, No start. I think if it was a key issue the truck would turn over, start, and shut down. Jump across the switch to see if it will start. You can use a paper clip. Just bend to fit.
Old May 26, 2006 | 06:03 PM
SkyHarborCowboy's Avatar
Reminds me of the time I borrowed my brothers Toyota. It is a nightmare to borrow anything from him. Anyway, I get to where I am going and kill the engine. When I try to restart it it wont start. I do everything I can to get the darn thing started and nothing. I call my brother and tell him his truck is dead. Of course he goes into a rage telling me I will never be able to borrow anything of his including a penny! He shows up and the truck starts right up! Of course I didnt know I had to push in the clutch to start the dumb thing!
LOL<
Joe
Old May 26, 2006 | 06:06 PM
wcjp's Avatar
I was reading on another forum about 06' starting issue. There's a yellow wire that helps control the starter. Apparently, it rubs against the oil dip stick tube(?) and shorts out. I'll be checking mine when the rains let up.
Old May 30, 2006 | 12:46 AM
dieselfumes57's Avatar
mine has done that same thing today!!! thank god it waited till i got home from vacation. its going in for service tomorrow
Old May 30, 2006 | 08:17 AM
Toto's Avatar
It's brand new...have DC roadside assisstance tow it to the nearest dealer and have them figure it out.
Old May 31, 2006 | 10:50 PM
Update: Dealer Says I Need Update 6.0.6 To Make My Truck Try To Start. Anybody Hear Of This? He Said There Was An Tsb On It. Oh Yeah Dont Let Me Forget, He Dont Have The Disk With The New Software And The Other Local Dealers Dont Either.
TNDODGE
Sep 13, 2012 01:38 PM
quads4_life
May 1, 2010 12:54 PM
4969joes
Mar 18, 2010 10:19 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
