Help me diagnose my surging problem.
Old Sep 3, 2013 | 05:12 PM
VaultRam's Avatar
First off a year ago my engine would idle up to 1k rpms sometimes for a few seconds as if it were cold outside going into high idle. Ran some BG244 and it never came back.
Fast forward to a couple weeks ago and I started getting a a surge between 50-60mph. I needed to service the tranny and thought adjusting the bands would help but nope. The surging seems to have gotten worse and really happens towing and when I hit bumps and bridge joints it surges even worse.
Can this be a FCA problem? If so, I'll replace the cascade overflow valve too. Should I replace anything else? The truck has 213k on the ticker and I have no fuel pressure gauge. Truck starts easily and runs fine, just surges between 50-60mph.
Old Sep 3, 2013 | 07:52 PM
Spooler's Avatar
Sounds like a FCA issue. Swap the cam sensor and crank sensor and see if things change.
Old Sep 3, 2013 | 09:51 PM
VaultRam's Avatar
Ok. Are you saying to change the cam/crank sensor first or just add that to the mix?
Old Sep 3, 2013 | 10:03 PM
Spooler's Avatar
What the heck was I thinking??? I meant to say replace the FCA. That should fix you up.
Old Sep 3, 2013 | 10:38 PM
VaultRam's Avatar
Gotcha. I was a little confused about changing the cam/crank sensor. Thanks for the help.
I'll order the FCA and a cascade overflow valve!!
Old Sep 3, 2013 | 10:45 PM
Spooler's Avatar
That post was actually for a different thread. I am still unsure how it posted to this one.
Old Sep 26, 2013 | 03:56 PM
VaultRam's Avatar
Quick question. Finally got the fca and was wondering how much lube to put on the o-ring? I've read Vaseline will work since I dont have any o-ring lubricant?
Old Sep 26, 2013 | 09:20 PM
rockcrawler304's Avatar
Just a small amount. All you want to do is keep it from tearing.
Old Sep 27, 2013 | 05:30 AM
Matt S's Avatar
If you changed the FCA and that didn't fix your problem, you might want to look search trouble code P2121. It's for the bellcrank apps. It can cause surging.
Old Sep 27, 2013 | 08:33 AM
dezeldog's Avatar
Also you may want to check ALL of the grounds as that was my problem with a surging issue. I cleaned them and put dialectic grease on all of them and ...good to go. HTH
Jim
Old Sep 27, 2013 | 11:00 AM
VaultRam's Avatar
Thank you
I replaced that last year when I got the dead pedal
Jim
Thanks for the tip!!
FLMarine
Jan 19, 2014 06:14 PM
ShaneCTD600
Mar 1, 2013 07:52 PM
wtmtnterror
Jan 24, 2007 10:07 PM
4x4dually
Mar 2, 2005 04:17 PM
HO Cummins
Nov 7, 2004 11:16 AM
