Help! Engine looses all power
Old Mar 7, 2008 | 08:30 PM
teamroper12v's Avatar
Hi all, I have been driving my dads 03 CTD and have developed a problem. When cruising down the road, 60 to 75 mph, the truck will just go back to idle and have NO throttle response. I know that the 2nd gen 24V would do this if the throttle position sensor would go out. Is it the same problem on a 3rd gen or is it something else? I have no codes, but I have also noticed a light haze at idle and sometimes it will idle a little higher rpm when you stop at lights and such. I dont know anything about the 3rd gen and any help would be great.
Old Mar 8, 2008 | 09:18 AM
Nobody out there can help me with this? Come on I need your experience.
Old Mar 8, 2008 | 10:03 AM
trik396's Avatar
When is the last time the fuel filter was changed?
When was the last time the air filter was changed?
It's hard to determine a problem without codes... Sounds like a fuel related issue. Could be a CP3 problem... or the FCA on the CP3. Give us more info...
Old Mar 8, 2008 | 10:18 AM
DiezelSmoke's Avatar
I am leaning towards air getting into the fuel system.
Old Mar 8, 2008 | 10:54 AM
03-HO's Avatar
If it idles and then won't run, it probly time for the pump in the tank. How many miles?
Old Mar 8, 2008 | 03:54 PM
MMacoustics's Avatar
If you have no codes:
#1 - I'd make sure the fuel filter is clean. If it has been a while since you changed it, start with that.
#2 - I'd check the exhaust flow. My cat clogged up one time causing loss of power. In fact the loss of power kept getting worse until I couldn't make it over 35.
Old Mar 8, 2008 | 08:29 PM
Ok, sorry I havent answered until now, but the air filter is great, fuel filter I am not sure about and the truck has a straight pipe with no cat or muffler. I have no codes, but it just feels like the throttle has no response like I said earlier that the 24v does when the tps sensor quits. The truck has 130K on it and has ran perfect until now, I just dont know.
Old Mar 9, 2008 | 08:43 AM
trik396's Avatar
An 03' with 130,000miles.... and your unsure about the fuel filter.... I'd start there first. If the stock fuel pump is still there, I'd take a hard look at that also. I would check/fix those two things first and foremost before moving on to anything else.
Old Mar 9, 2008 | 09:49 AM
Like I said, it is not my truck but my dad is very good about his service intervals and I am sure that it is fairly new. It just doesn't feel like a fuel problem, the power loss if instant instead of a taper off of power like with a fuel problem. It just falls off to idle and has No throttle, even with the fuel filter partially clogged up you should have some throttle response right? I will check it out though, thank for the help guys.
Old Mar 9, 2008 | 11:33 AM
gooseman495's Avatar
Chrysler has a TSB for no throttle response. It involves flashing a new program in the pcm. TSB # 18-027-03 This will have to be done at a dealer or if you know someone who works at a dealer, they can download the flash in a DRB2 and take it to the truck and flash it. A friend had the same problem with his 03, I flashed it and it been good ever since.
Old Mar 9, 2008 | 03:30 PM
thanks for the info, I will check into all of this. Any more suggestions?
Old Mar 10, 2008 | 02:55 PM
Yes, my wife has an 02 2500 5.9 and the discussions under "dead pedal" was helpful in working on her truck.
RIKNMAY
Dec 6, 2012 03:09 PM
NoSparkplugs
Feb 26, 2010 07:05 PM
lovinCTD59
Sep 26, 2009 01:06 AM
captaingeary
15
Oct 28, 2005 10:37 PM
SportTruck
Sep 13, 2005 07:32 AM
