Help with alignment
Old Dec 27, 2007 | 10:56 AM
cjurasek's Avatar
Help with alignment
I have used the search function here and on the TDR. I have still not found the info I'm looking for. My truck pulls to the right. It seems to be a problem with a few 3 gen trucks. I've noticed it more with the new 35" tires. I took it to the alignment shop (only does frame and alignment stuff) and they said the only fix would be adjustable or different ball joints. The truck only has 20,000 miles and I don't want to replace the ball joints. I've read multiple places about adjusting the caster 3-5 degrees positive. How can I figure out what 3-5 degrees is? Do I just move the cams (with the little ^ )towards the front of the truck? Will this help the pull to the right. I didn't get any numbers from the alignment shop. I've attached two photo's of my current caster setting. Thanks for all your help.
Attached Thumbnails Help with alignment-dtr1-3-.jpg   Help with alignment-dtr-2-2-.jpg
Old Dec 27, 2007 | 11:31 AM
John Faughn's Avatar
A good shop should give you a read out showing what the alignment is on the truck with the factory specs , then knowing if parts are worn or some damage has occurred , pot hole what ever .
Old Dec 27, 2007 | 11:57 AM
Shagginwagon's Avatar
Mine pulled hard to the left after the level lift was installed. Offset ball joints solved the problem.
I mean to the right.
Old Dec 27, 2007 | 01:41 PM
Hounddog's Avatar
Tons of these go right including mine.From all I've read since the 03 hit the ground is a off set ball joint.2ND gens ALSO did this and had a TSB for a adjustable ball joint.
Old Dec 27, 2007 | 01:45 PM
rjm022's Avatar
i have the moog adjustable/greaseable ball joints. when i had my truck realigned after replacing the whole entire front end-the alignment guy said my truck was the easiest truck he ever aligned! took him 30 minutes and the alignment was dead on!!!!
Old Dec 27, 2007 | 02:00 PM
TJAR66's Avatar
Heavily crowned roads will make you think alignment is the problem
Old Dec 27, 2007 | 02:27 PM
cjurasek's Avatar
I was hoping there was a cheaper (less expensive) way to fix the pull. I'm guessing its going to cost 4-5 hundred bucks to do the ball joints. Going to try and swap tires around to see if this helps. Thanks
Old Dec 27, 2007 | 02:51 PM
mikmaze's Avatar
what about an air presure adjustment, few lbs different right left, could help, or be the cause
Old Dec 27, 2007 | 10:12 PM
MLB 1's Avatar
Try rotating the tires first. Even if they're new, its cheaper than ball joints and another alignment.
J Lent
Jan 5, 2008 08:56 PM
rringstaff
Aug 29, 2007 04:11 PM
jmccart
Mar 7, 2007 12:33 AM
onelugnut
May 5, 2006 10:47 PM
jd03ctd
13
Sep 16, 2003 06:58 AM
