Have a leak from an unknown part
2005 2500, just over 80k miles. No longer a daily driver. Drive it a couple times a month.
Got home today and as I stopped in the driveway, smoke was coming out from under the hood.
Shut it down and popped the hood. Something was dripping on the exhaust just aft of the turbo and then burning off.
Must have been happening for a few miles on the way home cause you can see where it kept leaking and it was splashing over other areas of the engine compartment.
Looked around and it appears the leak is coming from this cap.
The top side of the cap has liquid pooled there and it's tough to tell from the photo but it was dripping down to the clamps and then to the turbo.
NOW here is my problem...I can't find that cap depicted on any parts diagrams. The HVAC plumbing diagram ends with the rubber 90degree hose and the HVAC units diagram only shows the supply and return to the heat exchanger.
Anyone know what part that cap and inline piece are? Or even what it's used for?
Thanks
Thanks
That is the "T" connection from a coolant flush kit. It appears to be the one that comes packaged with the Prestone Flush and Fill Kit. Someone cut that hose and installed the tee in order to flush the cooling system. The tees like the one shown in the photo are known for cracking at the cap or splitting at the neck below the threads. I do not recommend using a flushing tee at all for a few reasons. One of them being that they typically fail after a year or two.
Considering it wouldn't be worth the drive I ordered one and can hopefully install it this weekend.
Thanks for your help!
I would unscrew that cap and drain the coolant into a clean container. Best to perform this while the system is cold. You could also drain some coolant out through the petcock,albeit; they have a tendency to break for some folks. I recommend against that unless you are sure it will work. A best practice is to remove the lower radiator hose In order to drain some off.
ViperSBT
May 21, 2004 07:41 PM
