Harmonic vibration
Old May 8, 2018 | 11:01 PM
  #46
David Bliss's Avatar
Did you ever fix the vibration issues?
Originally Posted by junebug95628
Update on this vibration,
It has now been awhile since I first noticed this problem and it is now to the point where I can feel it empty.
Always between 1500 and 1900 rpm in second, third and OD most prominent with the torque converter locked up as then the motor and transmission are physically locked together.
Does anyone know of a tool that can sense vibrations and can be remotely monitored? Or some way to determine the source of a harmonic vibration?
Did you ever figure out what was causing the vibrations??
Old May 9, 2018 | 03:01 AM
  #47
rbertalotto's Avatar
Originally Posted by David Bliss
Did you ever fix the issue with the vibration?
I think so. I has a hydraulic damper installed for over $500.... but have not pulled traile4vyet. Without trailer it appears to be fixed.
homermandy
15
Oct 26, 2008 08:52 PM
ASHNBAK
0
Dec 15, 2007 08:03 PM
gatf4
Mar 9, 2005 11:52 PM
lightening ram
Oct 24, 2004 12:51 AM
