Harmonic vibration
I don't know if the damper and pulley will work on a 99.
Well, it sounds like this is the problem I have with my 5.9! I started a separate thread and then stumbled on this. Just ordered the 6.7 damper. pulley, and bolts from the local Cummins center. Parts should be in on Friday and in the following week. I guess the good bews is the fan had been removed when they did the cam so it SHOULD come right off.............right?
Since this is an in vehicle repari:
Anything I MUST remove to get the damper and pulley out/in?
Can I leave the fan shroud?
Do you have to remove the fan?
Any tips appreciated.
The bolts are not required.
I had to lower the fan but did not take it out after I got it loose to get the pulley out. I had replaced my fan clutch last year and used the tools from AutoZone. I flared the 36mm wrench and did not get the fan loose, had to use a hammer and chisel.
INSTALLATION
1. Install speed indicator ring.
NOTE: The speed indicator ring is located over a dowel pin.
2. Install the crankshaft damper and bolts. Tighten bolts to 40 N·m (30 ft. lbs.) torque, plus an additional 60°.NOTE: The damper must be installed so the hole is located over the dowel pin.
3. Install the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - INSTALLATION).
This is not TTY, as the bolts aren't stretch bolts. Its a TTT or wrench arc method.
When using bolts that are TTY and stretch you can feel it, and the new bolts I used on mine and the old on my dads were not any different.
Fluidamper mentions nothing about new bolts in their instructions and TDR write-ups mention reusing the bolts.
There are plenty of places where the service manual tells you not to reuse a bolt, and this isn't one of them. Nothing in the Cummins portion of the SM is labeled at TTY. Our head bolts are the same way, and they can be reused and specifically states the criteria for it.
AH64ID:
Thanks. After re-reading some other portions of the SM I see that Cummins uses this method throughout. I just never looked to see if there was a bolt stretch figure or not. Learn something new every day
The Fluidampr was delivered yesterday.
Installation was not difficult and required only a few tools;
13 mm combo wrench
15mm 1/2" drive socket
1/2" breaker bar
1/2" ratchet
Loosen the lower section of the fan shroud by removing the two 13mm nuts at the support. Remove belt from a/c compressor and pull slack around dampener. Remove 4 15mm bolts from dampener and support it, it may fall off. Remove dampener by finessing through fan blades and make a note where alignment pin in crank is. Coat new part's sleeve with antiseeze and finesse it up back through the fan (a little more difficult because it is a physically bigger part). Put pin in hole that aligns with TDC. Tighten bolts, pull belt back around a/c clutch, put two nuts to fan shroud back on and you're done.
Started truck, noticed that idle vibrations were different. Felt like the larger "stumbles" were no longer present. I do still feel vibrations but they are consistent and verry tame. When I took her for a drive I felt as though the big issue vibration was a lot different! You can still feel the truck enter that vibration range but within a split second it smooths out. I'll be hooking up the trailer for the true test shortly and will post back. So far so good....
13 mm combo wrench
1/2" breaker bar
1/2" ratchet
