Hard Starting
Old Apr 23, 2008 | 02:09 PM
DieselBoy20's Avatar
Hard Starting
The last couple of times i`ve started my truck up it doesn`t start as if it is almost air locked. So when it doesn`t start right away I usually turn the key off and back on again but just bump start it to get my LP going to maybe bleed the air and it usually does the trick. I do have a GDP 2 micron big line filter kit on this truck and I`ve checked everything for leaks and it seems ok, the filter has a little bit of gunk on it but it shouldn`t be sucking air at all. Could it just be that the filter is plugged....theres about 15,000kms on the filter now. I change my 7 micron filter every oil change and I just did an oil change about 2000kms ago. I also got a code P0148 High Pressure Common Rail it tells me. If anyone has any insight on this please let me know, im gonna change my 2 micron filter and see if that helps.
Old Apr 24, 2008 | 12:59 AM
okay, 39 views and not one reply ha someone has to have input
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
L. D. Bryant
Nov 17, 2002 12:18 PM
