Hard start
Hard start
07 cummins 3500 turns over loke its out of time. Kicks the starter out just before it fires .codes were crankshaft sensor/replaced it with new, cleared codes tried again same thing now codes read crankshaft and cam sensor /cleared codes tried again now shows code p2509 intermittent ecm power . Pulled air box over gave a small shot of starting fluid truck started and runs fine no noises nothing .shut it off and back to square one
Thanks for the info larry . I am aware of various problems using starting fluid on these types of pre-heaters I should have mentioned I cycled the heater 5or 6 times before using the starting fluid,lessening the possibility of preheater xplosion .still. I know this is not totally fail safe
jacob_armour
Feb 18, 2009 01:44 PM
jckdann7
Aug 31, 2008 12:13 PM
