Hard to get in Reverse and Second
Old Feb 2, 2008 | 08:29 PM
The Goat Man's Avatar
I have a 06 6 speed and it has become very difficult to get into gear when I am setting stopped. With the engine not running it goes in very easy. The truck has 98000 miles and am told the stock hydo clutch should be getting weak. There is no leaking that I can see but I know the main unit can by-pass internally. Is there a way to check this problem or should I just install a South Bend Hyd-x-750 and hope for the best.
Old Feb 3, 2008 | 10:24 AM
Jeff in TD's Avatar
Since it goes into gear easliy when not running, I'd suspect the clutch is dragging?
Old Feb 3, 2008 | 11:54 AM
What is the repair for a dragging clutch? Or what would cause a dragging clutch?
Old Feb 3, 2008 | 08:17 PM
renopker's Avatar
Replacement is the repair this has a dual mass fly wheel you've done good to get that much life out of it.Look at the valair conv clutch and flywheel kit got one last week for my g56 conversion its the way to go.Good luck
Exekiel69
Cummins Conversions
Jul 9, 2011 12:49 PM
enydick
Aug 14, 2010 10:20 PM
jmccart
15
Nov 24, 2007 05:31 PM
Baja
Aug 20, 2007 01:08 PM
97Dually
Apr 22, 2003 06:08 PM
