Gut the cat or lose the muffler?
Old Dec 28, 2008 | 09:10 PM
jcrowe01's Avatar
I have an 04.5 dodge 2500 and I want more sound. I don't want to much sound where it is annoying. I figure if I lose the cat it will equal more power than if I lose the muffler but I figure losing the muffler will give me more sound. Am I right about this or wrong?
Old Dec 28, 2008 | 09:23 PM
'strokeThis_'07's Avatar
The first thing I did to my truck when I got it was remove the muffler, but kept the cat. Sounded pretty good. Wasnt as loud as I wanted. But Im still running it 2 years later. It sounds good, louder than stock, but not as loud as a straight pipe turbo back does...
Old Dec 28, 2008 | 10:06 PM
Highway 4x4's Avatar
Don't touch the cat, all we need is more ammo for the feds to require smog checks on our diesels. Remove the muffler and dump it in front of the rear axel. Pull the turbo ring and add a BHAF. That should do it.
Old Dec 28, 2008 | 10:58 PM
AH64ID's Avatar
When I first bought my truck I ditched the muffler and left the cat. I really liked the sound, not too loud, not too quiet... But then I started working the motor a little more when towing and it was annoying loud and it droned while towing...
Now I have ditched the kat and have a Donaldson 40" under there.. I am super happy with it in all modes (thou I am adding a Megacab resonator to kill the high freq from the EB at idle)
Old Dec 29, 2008 | 07:20 AM
Coolride's Avatar
My cat is blown out, and I have an MBRP straight thru muffler on it, and you'd think it was stock. I'm thinking next the muffler has to go, these diesels don't want to make sound. When I pull my 5er it has a little roar to it, but barely. I think if you get it just the way you want it, it will be to much when towing though. It's so easy with a gas truck to get it sounding right, just loose the mufflers, or turbo muffs. and they sound just right too me. I've heard some nice Fords around here though, sounds like their spooling up a JT-8 turbojet.
Old Dec 29, 2008 | 08:47 AM
TX_Diesel's Avatar
That's because of the variable vein turbos...we won't be able to get that sound. I've never ditched the cat on any of my dodges but took all the muffs off and it sounds good, no drone, but not real loud, this go around I too was thinking of straight piping it.....you could always add a muff later if it's too loud. The one thing i dread is drone.
Old Dec 29, 2008 | 09:11 AM
BMH95's Avatar
I have the cat, but the muffler fell off a while ago. I like it. Make sure it's hung well and tight, and you won't have a drone.
Old Dec 29, 2008 | 09:12 AM
BMH95's Avatar
Did I just say my truck is well hung? I meant make sure you use enough exhaust hangers, and that they are all carrying an equal load. Also, ensure that the clamps are tight in a natural resting position, not tweaking or holding the exhaust straight - that's the hangers' job.
Old Dec 29, 2008 | 09:30 AM
Swayse's Avatar
I emptied my cat and ran stock exhaust for quite a while. Then I got a wild hair and took off the empty cat and added a short resonator to the stock (muffler and all) exhaust. Faster spool up, I noticed that right away. I wouldn't waste my time with emptying the stock cat, just take it off.
If you wanna run an empty cat, I'll trade you mine for your full stock one.
Old Dec 29, 2008 | 10:05 AM
That was good right there...haha!!
Old Dec 29, 2008 | 10:56 AM
93-331-29psi's Avatar
I think that the air filter is the key to the big rig sound. I put 5" magnaflow on without the muffler and while it was louder than stock at idle it was nothing like I expected it to be. I did install the magnaflow muffler and I have a little drone when under load, but at cruising speed all is quiet. That is what the radio is for anyhow, to drown out the sounds.
Old Dec 29, 2008 | 02:22 PM
jcrowe01's Avatar
If I take off the cat and put in a piece of pipe will there be a difference in the sound?
Old Dec 29, 2008 | 08:39 PM
rockcrawler304's Avatar
I still have the cat but ditched the muffler and love the sound. Being a Megacab I do have the resonator and that might be a big difference.
Old Dec 31, 2008 | 06:07 AM
Swayse's Avatar
Yeah, little deeper and a little louder, not much though.
Old Dec 31, 2008 | 08:10 AM
mcolectd's Avatar
My muffler and Cat were gone the day after I bought my truck
