Going to Dealership for service/need advice!
Old Sep 5, 2005 | 04:59 PM
TXPOWER's Avatar
I recently began to feel quite a vibration coming from underneath my 2003 CTD with automatic tranny between about 65-75mph. It was never there before. I also hear a squeeking when I reverse and an odd sort of tapping noise going forward. I got under there thinking it was the u-joints, but they still look good and feel tight. As best I could tell, the squeek in reverse sounded like it was coming from the very back of the transfer case where the driveshaft yolk stabs into the output shaft. I did notice the little rubber boot on the transfer case at that location is dry rotted. I also observed Dodge put some sort of what looks like a harmonic balancer on the driveshaft in the same area. It could be coming from there but I was unable to determine that for sure. I'm going to take the truck to the dealer tomorrow for service and wonder if any of ya'll have had similar issues and if there is anything I should look out for. I have never used the dealer before and hope I don't have to educate them or help them diagnose the problem but we all know how that goes.
Thanks,
TXPOWER
Old Sep 5, 2005 | 07:55 PM
natstayl's Avatar
Longbed or short?
Nat
Old Sep 5, 2005 | 08:08 PM
dodgetech77's Avatar
Still sounds like u-joints
Old Sep 5, 2005 | 08:13 PM
natstayl's Avatar
Longbeds had a lot of complaints with the 2000-2500 RPM 70MPH drive shaft rumble. Did you try a search for "70 MPH vib"
Nat
Old Sep 5, 2005 | 09:31 PM
RIPnROAR's Avatar
I would also say u-joints.
Had the same symptoms on another vechicle years ago. Crawled underneath and checked the driveline and all appeared fine but could not think of any other explaination so pulled it anyway.
Yep, the needle bearings were powder on two of the cups, and the others were on thier way to becoming the same.
Drive careful on the way to the dealership, and good luck.
Old Sep 5, 2005 | 10:55 PM
TXPOWER's Avatar
It's a short bed quad cab. If it is u-joints, chances are that ain't covered is it?
TXPOWER
Old Sep 5, 2005 | 11:32 PM
RIPnROAR's Avatar
Warranty
7 yr. 70,000 mi. Warranty I would think so.... unless they thought they could claim abuse somehow.
They should fix it no problem. Minus deductuble.
Old Sep 6, 2005 | 12:06 AM
crobtex's Avatar
I don't know where you are in North Texas, but stay away from the dealer in Richardson. I have also been to Plano, Mckinney and Sherman. Sherman seems to have the best service and most knowledgable people.
Just my opinion................
04ctd
Sep 9, 2010 08:27 PM
northernwheeler
ABDTR #5
20
Nov 30, 2009 05:06 PM
Redbeard
19
Dec 29, 2007 01:05 AM
Rich Baars
25
Feb 8, 2007 05:54 AM
gbcop
Jun 22, 2006 03:23 PM
