Getting the Belt off
Old May 27, 2010 | 11:47 AM
Tedonlin150's Avatar
Ok I did a search on here and on google but I can't really find anything. I'm trying to take the serpentine belt off so that I can do the tone ring mod. What I've done so far is put a socket on the tensioner bolt and tried turning it to the right to relieve the tension. All it did was tighten the bolt. Am I doing this wrong? Thanks for your help.
Old May 27, 2010 | 12:12 PM
1-2-3's Avatar
Just a plain ole guy
Your probably on the wrong bolt. The tensioner pulley should swing fairly easy.
Old May 27, 2010 | 12:17 PM
I'll have to double check but I thought there was only one bolt on it.
Old May 27, 2010 | 12:32 PM
Purplezr2's Avatar
I thought it was just a square cut out in the tensioner that you insert the head of the ratchet into.
Old May 27, 2010 | 12:43 PM
dezeldog's Avatar
X2 what purple said. It's a 1/2 in hole to slip a breaker bar in and pull down. Then you can just slip it off of the a/c pully and ur done.
Jim
Old May 27, 2010 | 01:07 PM
Yep, I just figured that out myself but thanks anyways guys.
Old May 27, 2010 | 01:46 PM
15 Digger's Avatar
Question, what is the tone ring mod?
Old May 27, 2010 | 02:11 PM
There is a toothed wheel right behind the harmonic balancer for the crank position sensor. You can turn the wheel clockwise to advance the injection timing. Do a search and there is a right up of how to do it.
Old May 27, 2010 | 04:00 PM
1-2-3's Avatar
I was thinking square too but wasn't 100%. Been awhile since I took a belt loose.
Old May 27, 2010 | 08:14 PM
Mexstan's Avatar
Definitely no sockets are required to slacken the tensioner. You only need a 1/2" drive ratchet and maybe a pipe to extend the ratchet. Also, the belt does not need to come completely off, but only off the lower (crank) pulley and then the tone ring mod is easy to do.
Old May 28, 2010 | 01:41 PM
15 Digger's Avatar
Thanks, knew about wheel but not that you can adjust timing.
DodgeDiesel61
Jan 26, 2019 07:45 PM
M Penwald
14
Mar 26, 2011 08:41 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
apwatson50
Mar 3, 2006 06:26 PM
Lightman
Oct 27, 2003 04:08 PM
