Which Gauges??
Old Jan 19, 2009 | 05:48 PM
man doore's Avatar
Which Gauges??
I am looking to get some gauges for my 05. I know i should get a exhaust temp and a boost gauge...is there any other important gauge that I should have??
Mind you I have a manual transmission so a transmission temp would be pointless right?
Old Jan 19, 2009 | 06:55 PM
trik396's Avatar
Oil pressure and fuel pressure are kinda important. I also have turbine inlet pressure, oil temp, low oil pressure warning light.... of course I am excessive that way...
Seriously, fuel pressure would be what I'd get next if I were you followed by oil pressure.
I prefer Autometer gauges.
Old Jan 19, 2009 | 10:06 PM
ratsun's Avatar
I second a FP ( lift pump) gauge
Pick a style you like
Old Jan 20, 2009 | 12:55 AM
CrashCade's Avatar
Personally, I think Low and High fuel pressure are important along with Pyro and Boost. I guess if you wanted to be redundant you could install an oil pressure gauge as well. I also like the idea of knowing what Drive pressure is!
Old Jan 20, 2009 | 03:27 AM
snoyes's Avatar
Another vote for Fuel Pressure to be your third gauge. I've had good luck with Autometer as well.
Old Jan 20, 2009 | 06:03 AM
trik396's Avatar
two is one.... one is none...
Old Jan 20, 2009 | 01:12 PM
AH64ID's Avatar
Oil psi isn't redundant, the one on your dash is fake...
I run Boost, EGT, Fuel Pressure, Rail Pressure, Drive Pressure, and Oil Pressure.
If I only had 3 it would either be Boost, EGT, Fuel or Boost, EGT, Oil.
Hoss
Dec 2, 2012 01:59 PM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
