Gauge Install Question
Old Feb 3, 2008 | 09:03 AM
The Big Z's Avatar
I am getting ready to install the following gauges (EGT, Fuel Pressure, Boost, and Tranny).
My question is what type of sealant, loctite or anti-sieze do you use on the threads?
Tranny Sensor?
Banjo bolts for Boost & Fuel?
Boost & Fuel Sensors?
EGT Sensor?
Thanks
Old Feb 3, 2008 | 09:55 AM
billie's Avatar
I use "Ultra-Black" silicone on all threaded connections near oil or fuel. Clean oil off with brake cleaner and fill the male thread grooves, smooth, install then wipe off excess. Tighten firmly but don't over tighten, it won't be needed.
I've been using silicone in threads for several years now and never a leak. I've had lots of failures with other seals around liquids but never with silicone. Just use a silicone that matches the fluid. I don't like RTV Blue as it isn't as good as black around oil.
Cya
Old Feb 3, 2008 | 10:14 AM
CamperAndy's Avatar
Tranny Sensor - Depends on where you put it so need more info
Banjo bolts for Boost & Fuel - Teflon pipe dope
Boost & Fuel Sensors - Teflon pipe dope
EGT Sensor - High temp anti-seize
On the pipe dope, it only takes a very small amount to achieve a quality seal. All surfaces must be clean and dry when the parts are put together.
ado2b1
Jul 6, 2007 10:27 PM
chrismez
Sep 3, 2003 08:23 PM
jbs007
Jul 24, 2003 12:58 AM
apc
Apr 8, 2003 05:51 PM
White02Sport
Oct 6, 2002 07:11 PM
