g56 tranny question
g56 tranny question
Hi there folks. I have 2004.5 with 220k on it and my manual 6 speed is starting to get hard to get into gear when starting out. Once rolling it is much easier. The clutch was change out at 175k. It is also getting harder to down shift. This is not a grinding the gear thing it just doesnt want to slip into gear like you cannot find it. Any thoughts out there. Is it looking like I might need a rebuild and how much does that cost.
Thanks for you help
Thanks for you help
After you guys gave me the right tranny info I was able to search a little bit more. I couldnt get a feel on how often folks change there gear oil. I had it done about 40k ago but have owners found it better to change at every 20k, 30k? Some folks have commented that if the oil gets a little old that you would not be able to shift well. As far as pulling it myself I wouldnt have the time. I work way to many hours and would most likley break something. My old fingers and back just can not climb under trucks anymore.
Thanks
Thanks
q56 tranny question
When you change the transmission oil, add a small can of Slick 50 Transmission conditioner. It's amazing how much smoother that stuff makes manual transmissions function. I ran it in a manual transmission for over 200K with zero trans problems.
I just looked up the info on the last oil change and they did not use the right oil for my tranny. Thanks for the input and will be going to a new shop and getting it changed tomorrow. It sounds like at the last change they put in just gear oil. The mechanic I have scheduled with said its a special blend and its $20 a quart. WOW..
I will let folks know if it helps..
Just drove my truck for work with the new oil in and it shifts almost like new. Had them service the front and rear end as well and the whole truck is much quieter then before... shows that you need to take your trucks to someone you trust..
Thanks for all the input from everyone
67guzzler
18
Apr 25, 2007 09:06 PM
Steve034x4
Dec 12, 2005 08:21 AM
