G 56 question
Old Oct 19, 2007 | 07:13 PM
Diesel Junkie's Avatar
my 92 has 35" tires and 3.54 gears with an Nv4500.... I think the final drive gearing is perfect.
My 07 has the 3.73s and I now I need to check that serial number... i bet i have the older low gear OD in my G56... I ordered mine in late November, and it was picked up a couple days befor 01/01/07.
but I think that with some taller tires it will be perfect.
I think these gearing preferances have a lot to do with how fast you like to cruise at on the freeway.
Old Oct 19, 2007 | 09:47 PM
Buckshotmckee's Avatar
I love mine! When towing its awesome! I had 315s on my 02 with 3.55 and the NV4500 and I will gladly take the way my 06 is set-up over the 02!
Old Oct 20, 2007 | 10:32 AM
D-Roc's Avatar
Here it is. An 08 with 3.42's and G56 would be awesome!
Old Oct 20, 2007 | 12:06 PM
It just so happens I'm sitting here at the dealer with my PT cruiser and after reading this I decided to check the lot to see if they had one. They do and I drove it. I noticed the truck runs about 300rpms lower then my 06. It's definitely longer legged. After driving the 08 with the 3.42s, 6.7, my 06 definitely feels stronger. If you are going to use the truck for a daily driver and tow moditeratly, this is the set up for you.
Old Oct 20, 2007 | 12:28 PM
D-Roc's Avatar
Is that truck with 3.42's that you drove a six speed manual?
Old Oct 20, 2007 | 01:02 PM
Yup!(stupid 10 character)
Old Oct 20, 2007 | 05:28 PM
Mopeman's Avatar
I was thinking the same thing, I don't really want to go 3.42's, I also don't want to go 35 inch tires either. I think the higher gear set out of the newer G56 would be perfect with 285's for me. It would bring the 75MPH RPM's down, and help out with the MPG's when unloaded. I don't want to lose any towing ability, that's why I bought the dang truck to begin with.
Old Oct 20, 2007 | 06:04 PM
dminer's Avatar
I have an 06 G56 with the 3.73's and I like it.
Old Oct 20, 2007 | 06:13 PM
scootertrash35's Avatar
if i lived in a 55mph state,or never hauled heavy i would probably like it
Old Oct 20, 2007 | 07:46 PM
nitis's Avatar
I think I am going to do cause
" I just wanna go fast"
and I really wanna step down a tire size too.
another thing to consider is those new 6 speed manuals are higher geared than the old ones and they have 3.42s so the old with the 3.42s should be a happy medium.
Old Oct 21, 2007 | 02:55 AM
jtrimmell's Avatar
Im not sure what my tranny has for gears but mine was manufactured in december of 06.
Old Oct 21, 2007 | 10:50 AM
VFDFireman's Avatar
Why not just get a GV overdrive? Yeah I know they they are a bit spendy, but it's got to be near the price of swaping the tranny out or upgrading the final gear. It's probably cheaper to change the gear set or bigger tires, but why not have the best of both worlds?
Old Oct 21, 2007 | 11:42 AM
levigarrett76's Avatar
because of the weakness for us who haul heavy...especially backing up hills, i bought one and returned it before i ever installed it
i back 12-24k up hills quite frequently and after alot of research i realized i would have toasted my GV, especially since i plan to run this truck over 300k
Old Oct 21, 2007 | 02:54 PM
53 willys's Avatar
if all you had to do was buy the new 6th gear and you installed it yourself..theres no way it would be the same or even half of what a GV unit cost.
IF you could buy new G56 6th gear I bet you would only spend $200-300 bucks.... thats WAY cheaper then regearing the axles or even bigger tires!!!! even if it cost $1,000 it would still be the cheapest route.
my .02
Old Oct 21, 2007 | 07:34 PM
nitis's Avatar
but can you buy just the 6th gear that is exactly where I was trying to go with this 53 thanks
