Funny Cold Start
Old Dec 10, 2008 | 10:03 PM
cuminpwrjr's Avatar
Funny Cold Start
Latley its been about -5 C and when i start the truck it will kick right in to high idle about 1000 rpm. just wondering if this is okay or am i looking at increased wear?
Old Dec 10, 2008 | 10:12 PM
dslpwr81's Avatar
It is normal, but I don't care what anyone says, that is hard on them. That is a rough dry start. Find anyway possible to plug it in. That is increased wear at its greatest.
Old Dec 10, 2008 | 10:13 PM
cbrahs's Avatar
step on the brake RIGHT after start up. it will kick it back down, let oil psi build then let it go to high idle.
Old Dec 10, 2008 | 10:40 PM
cuminpwrjr's Avatar
I've tried the brake a couple of times, but ill trie again i usually end up putting it into neutral and letting it warm up
Old Dec 10, 2008 | 10:49 PM
dslpwr81's Avatar
Neutral allows the tranny to warm up. It will circulate. You have to be fast on that brake pedal, but it will still hit 1000. Try and warmer up.
Old Dec 10, 2008 | 10:52 PM
cuminpwrjr's Avatar
What are the chances of it still hitting 100rpm on start up when i get my remote start fixed?
Old Dec 10, 2008 | 10:55 PM
dslpwr81's Avatar
It will still do it. Try and plug it in. Get a timer.
Old Dec 10, 2008 | 11:09 PM
cuminpwrjr's Avatar
yeah im doing that for friday night it forecasted for -30 w/o windchill i figure 2-4 hours to plug it in
Old Dec 11, 2008 | 12:41 AM
dslpwr81's Avatar
That would be great. Most people usually do around 3 hours. When it is that cold, I usually plug mine in all night. That heat transfers to the oil a little. Warms it just a bit. Some will disagree, but with a heat gun, it will tell you.
Old Dec 11, 2008 | 12:09 PM
DBLR's Avatar
When it hits -30 below zero I like to plug mine in for a full 4 hours and close off all 4 panels on my winter front until the outside temps get up to 10 degrees. BTW wind chill has no affect on your truck, wind chill only affects living things like humans and animals.
bullfrog5.9
Jan 3, 2010 05:41 PM
Flatbed24v
Dec 5, 2008 11:23 AM
big stinky
Apr 23, 2008 10:49 PM
