Fuel Transfer Pump HELP!!!!
My transfer pump wen out in January and I replaced it with the replacement from Geno's Garage:
http://www.genosgarage.com/REPLACEME...MP_FPD4089602/
Tonight I noticed it took a few second for it to started. I then noticed the humm from the lift pump was gone. This was the same thing that happened last time.
My question is should I replace it with another kit or go with a aftermarket like the FASS system?
Thank you for you assistance anyone can give me. Thank you.
that pump will never last. either get a tank mounted pump or mount a brushless pump on the frame, either way add the filtering by the pump or tank. gemos is suppose to be handling the new carter brushless
I have a Walbro 392 mounted on the frame rail. I've had it for over 70k mi without a hiccup. Glacier Diesel used to sell the entire kit but I 'm sure that Richard would hook you up with all of the fittings and buy the pump from Summit Racing.
Ahousat Diesel
22
Jan 12, 2014 12:05 PM
8mpg
May 22, 2006 01:35 PM
