fuel system filtration and pump questions!????
Old Dec 31, 2009 | 05:41 PM
Jordan5687's Avatar
Question fuel system filtration and pump questions!????
Ok, been reading a bunch of stuff on this. I am gonna do a water/fuel seperation before the stock pump. And a cat 2 micron filter between the stock filter and the cp3, I was thinking of doing the holley black pump, I wanna do an efficient but cost effective way to have a pump and filter setup. I already know how ill do the filtration. But I need ideas and info on the pump, should I run it in conjunction with the stock pump, or bypass that? Or is there another real good pump, or maybe replace the stocker with another? Any ideas would be great, thanks!!!
Old Dec 31, 2009 | 06:12 PM
rich's Avatar
believe the airdog comes with the complete filter set up.
Old Dec 31, 2009 | 06:31 PM
Jordan5687's Avatar
Yeah I know that and the fass does but I can build one for half that price. I don't have a huge budget right now and need to do it soon.
Old Dec 31, 2009 | 09:27 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
https://www.dieseltruckresource.com/...=181485&page=6
read my post #82 on page 6
I detail everything you need to know about getting rid of that pesky stock lft pump and running holleys.
You can make a pump block-off plate like one I did.
https://www.dieseltruckresource.com/....html?t=191118
post no. #5
read the pdf.
Old Dec 31, 2009 | 10:40 PM
Jordan5687's Avatar
Well I can build the same thing for half the price, that's why I don't buy a complete setup already.
Also wondering on the water/fuel seperator is it better to push the fuel through, or pull it through?? Was reading somewhere one of those is better cause of water emulsion.
Old Dec 31, 2009 | 10:46 PM
Jordan5687's Avatar
Whoops, didn't realize I responded to the same one twice. Ok ill check it out better tmrw, I'm on my blackberry now. I did see pics of the twin holleys, very very nice, what about a T from the tank feeding them separate? And then coming back into a T after? Or is it kinda all the same? How reliable are the holleys?? Right now I'm pushing out 440hp, and yet to add the smarty, should that be fine for the holley?
Old Dec 31, 2009 | 10:49 PM
Jordan5687's Avatar
My LP is not an in tank, its nearly below the stock filter. What is that pump block off plate for?
Mykdiver
19
May 29, 2011 09:42 AM
easinc
22
Mar 31, 2011 11:22 PM
Tiara3100
Dec 21, 2007 01:42 PM
rattle_rattle
25
Oct 12, 2003 12:56 AM
